Which paint? How much?
Discussion in 'The Body Shop' started by K5MONSTERCHEV, Oct 26, 2004.
  1. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Ok im going to try and throw a coat or 2 of paint on my blazer this weekend for the good guys, and the primer has faded and once again, looks like crap.
    My questions are, how much to spray 2 coats of gloss black on it? 1 quart? I think thats how much primer I used. I might paint th ebottom half white, like I posted a wile back. Also, what brand? Im not sure what the paint place carys, I used PPG primer, so im guessing PPG paint.
  2. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    PPG is about the best. I would imagine it would take 2 quarts to do a complete job on a blazer with 2 coats.
  3. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    it depends on what you abilty is.
    HVLP or std. gun?
    if your not after a show finish, get a gallon of Acrylic Enamel.
    when i painted mine, we used almost 2 gallons with a HVLP gun.
    my dad and i painted my sons s10 Dupont Centari, we used black primer and paint, and it still took almost a full gallon.
  4. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    No im not after ashow finish at all. I just want to throw some paint on it, for the show. Ill get it professionally done for the final paint, with all new body panels.
    I dont know what HVLP even is, I ll use a gun.
    So acrylic enamel, can you tell me a little more about it? I dont know all that much about paint, sorry. It was something Inever got into, and was jsut gonna let the "pros" do it.
  5. dodgedude99
    Jul 12, 2003
    784
    burbia of illinois
    HVLP = High Volume Low Pressure, it means more paint gets on the car instead of the air.
    its better for the enviroment, your garage, wallet, and produces a nicer finish.
    you can pick up a HVLP gun from Harbor Freight or Ebay for like $50 for a economy model.
    Acrylic Enamel is a durable paint thats fairly cheap and easy to paint (i played around with it spray bikes, skateboards, and tonka toys when i was like 10), and dries almost as quick as the other stuff.
    this stuff is a fairly good deal.
    you would need hardner and some enamel reducer.
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2489471666&category=63702
    and im sure someone will chime in about Enamel, but for a cheapo paint job that doesnt turn out half bad, its great.
  6. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    2 quarts of PPG DRU- Which then gets reduced down to at least 1:1 IIRC-. In the end 2 quarts gives you about a gallon, which is enough with a HPLV gun, but not really enough with a standard gun.
    If you want just a quick one, get the single stage, rather than a 2 stage. That way, you just spray, let dry, and sand.
    Otherwise, you have to spray, flash, spray, flash, spray clear, flash, spray clear again. ( I think, Im still learning)
  7. dodgedude99
    Jul 12, 2003
    784
    burbia of illinois
    hey Pookster, that also depends on the color you are putting down also.
    the GM Sunburst Orange Metallic i used on mine, i used 1.75 gallons of unmixed paint.
    i think it depends alot on what color you are spraying.
    black goes on quick and easy, especially if you use black primer.
  8. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    /forums/images/graemlins/doah.gif
    Forgot about color. Dark colors offer better coverage than light colors.
    I recall red being more expensive than blue, and then other darks, then white. Something like that.
  9. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Thanks guys. Looks like theres a lot to lear about paint. I didnt get to do it this weekend, I went out of town, but im gonna go get paint today and try to shoot it this weekend.
  10. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    If i was gonna do it again, I'd probably do the single stage than the two stage- Single is easier to shoot it seems, two stage requres a clear coat.
  11. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    yeah ill probablly do that. i dont need clear, its just a "for now" job.
  12. dodgedude99
    Jul 12, 2003
    784
    burbia of illinois
    reds and yellows and oranges are the most expensive colors, and the prices go up as flakes and such are added.
