which plugs?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by therover87, Jan 10, 2002.
  1. therover87
    therover87 1/2 ton status
    Jun 24, 2001
    139
    Long Island, New York
    i have an 87 k5 350 tbi and i am going to be doing a tune up soon and was wondering what plugs you guys have been running and how you liked them, thanks.
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    A-C Delcos always work for me. I also use Autolite now and then. I like them both.
    <a target="_blank" href=http://coloradok5.com/gallery/Thunders-Blaze> Blazer pics</a>
    <font color=blue>Nevada... Where the pavement ends and the west begins
  3. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    i used regulr bosch they work good......i guese
    hola
  4. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    Ac Delco Rapid fires, Best plug for the money
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I use Champion Truck plugs in my Jimmy, and my Dad had me put them into his 2 other trucks because I liked them, and they worked well.
    My Chevy isn't broken, its just out of gas.
  6. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    i like my split-fires.
    --Scott, 1989 GMC Suburban 2500 4" lift, 36" TSLs
    <a target="_blank" href=http://community.webshots.com/user/muddysub>http://community.webshots.com/user/muddysub</a>
  7. Headbanger
    Headbanger 1/2 ton status
    Nov 29, 2001
    123
    Moreno Valley, California. U.S.A.
    I agree with slider, I've used alot of different plugs and the AC Delco Rapid Fires work great on higher mileage engines(100,000 +)
  8. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    go with the AC Delcos. for non efi use the regular ones. for efi i heard the platnium ones make a diff.
    ARQ.
    offroad baja!!!
    72 4x4 CST Blazer
    71 4x4 CST Blazer
    <a target="_blank" href=http://coloradok5.com/gallery/ArqDennis>My Pics</a>
  9. holyjohnson
    holyjohnson Registered Member
    Nov 22, 2001
    94
    the fringe of insanity (only on mondays)
    delco R45-T or R45T-S depending on your prefered gap and how hot or cold you want to run it.
    "well,are you gonna pull them pistols,or whistle dixie!?"
  10. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    Im running some autolite platnium plugs on my motor and i havent had any problems with them. $2 a plug aint bad wither compared to the $5 for the rapidfires
    My 73 K5 <a target="_blank" href=http://www.geocities.com/xk5blazerx/73k5.htm>http://www.geocities.com/xk5blazerx/73k5.htm</a> 350/TH350/NP203, Q-jet, Edelbrock intake, Vortec heads, 4" lift, and 36" TSL's
  11. Slayer
    Slayer 1/2 ton status
    Oct 17, 2001
    225
    Eastern Colorado, jokingly referred to as Western
    <font color=blue>I was completely surprised to hear what the "experts" had to say about spark plugs.
    </font color=blue><font color=green>I asked 14 GM/Chevy (my IQ goes down too far when I get near the F**D's) hill climb racers what plugs they run.
    Every one of them said that they used the cheapest AC Delco plugs available.
    </font color=green><font color=red>I asked about RapidFire's, Bosch (especially those ultra-expensive platinum quad-tips), other manufacturer's platinum tipped plugs, split-fire tips, etc, and got the same response; "You're throwing away your money".
    </font color=red><font color=orange>
    Their ONLY advice was to index the plugs.
    Indexing is where you mark the tip of the plug to show which direction the electrode tip is pointing, then screw the plug in to see where the electrode tip ends up pointing. You then add spark plug shims until the electrode points directly into the "squish" chamber.
    Spark plug indexing shim kits are available at just about all auto parts shops.</font color=orange>
    <font color=blue>I don't know everything, I just think I do.............</font color=blue>[​IMG]
  12. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I asked a Checker parts buy about the Bosch 4 tip plugs, and he told me that every set he sold for a SBC came back fouled. Not to mention they are really expensive.
  13. Neil
    Neil 1/2 ton status
    Jun 10, 2001
    275
    Dothan,Alabama
    AC Delco R45T is the best for a stock motor even with a few modifications. If you do a ignition or intake\fuel upgrade or add a cam or some more serious modifications, go to a R44TS to be cooler and more power. Indexing plugs is only for serious racing engines and people with a complex about indexing. It has very little additional power effect on street or our 4x4 off road engines at all. Indexing is a more direct path from valve to plug and shorter spark traveling distance so there is no wasted compressed o2 &amp; gas supposedly. It is a good theory, but only if racing or you want to go thru the headaches of doing it. Again, not necessary on non-racers.
    Neil H. Alabama.. "It's a full size thang, Jeep owners don't understand!!" '78 K5 400ci 4x4 AT,AC,PW Cheyenne., '74 C10 4x2
