which q-jet?
Discussion in 'The Garage' started by BranndonC, Feb 9, 2005.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    which q-jet/carb? $500 to spend
    I just started looking for a carb for my motor. I wanted a holley off road carb, but was informed that a q-jet is better. So I went in search of a q-jet from holley, i couldnt find one at jegs. Do they make them? Also are they all universal bolting? or do i need to find one specificaly for my engine?
    Thanks.
    Oh and the motor revs to about 5000, and should make abour 400hp/550tq, what cfm should i get?
  2. WantedaDodge
    WantedaDodge 1/2 ton status
    Dec 16, 2004
    282
    Eugene, OR
    JET tunes Qjets don't they?
  3. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I bought from here Clicky , 3 days from phone call to my door . I told them my setup , and it was close , not too much tuning for me :D
  5. WantedaDodge
    Dec 16, 2004
    282
    Eugene, OR
    I have to say, I really like the Holley Avenger series carbs.
    I have a 670 Street Avenger on my Challenger. It works awesome! It's pretty tuneable, not as much as a classic 4150 but it's got some real nice features. All I had to do was jet it up(I think it came w/ 65-68s, I put 72-76s in) and adjust the vacuum secondary.
    I might put that carb on my blazer though and put a 700 double pumper on my car. I was told it could use more carb. I have a friend with an O2 sensor Air/Fuel meter and I have a bung in my exhaust, we'll probably do some more tuning on it this april.
    But I would say go with the truck avenger...
  6. dyeager535
    26,979
    Just to throw in my worthless $.02, DAMN thats a lot of money for a freaking carburetor that started in production in 1965! :)
    Thats the kind of money that will get you converted to TBI just about.
    If there are automotive swap meets around you, $5 isn't unreasonable for a used Q-jet that can be rebuilt for $20 in parts, maybe additional $40 to have it bushed.
    The stock 750 or 800CFM will be fine for you. Better torque with the 800 apparently.
  7. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    the cheapest tbi i've seen was over a grand. can you point me to where i might find it cheaper?
  8. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    You are going to be running a 500 Caddy right? If so I would not do TBI on it.
    I have 2 friends with 454's that have TBI setups on them. They are both better then stock HP's and the TBI will not support the power of the BBC. They do great on monster torque at the low end but the TBI will not flow enough air to allow alot of upper RPM HP's.
    I have been in both vehicles and they both flatline for power around 3500 RPM. A bigger motor is just going to compound the problem.
    Harley
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    They are pricey , I just bought one versus any conversion toTBI over the time factor , I drive mine to work everyday , and didn't want to bother bushing mine . I have time to bush it for my project though :D
  10. dyeager535
    26,979
    OK, caddy motor is going to cause some issues, especially a 500 lol.
    I'd suspect that with a motor that large turning that high, even the 454 setup won't help you, so I will retract that comment about $350 or so buying you TBI. :) I have seen TBI setups for small blocks running around that cost though.
    Whenever the classifieds on thirdgen.org start working again, that would be a good place to check for cheap TBI though, as well as our own for sale section.
    A motor that big I'd go with the 800 variant...but CFM vs. CID wasn't the determining factor in GM's eye apparently. If buying one brand new, and the motor is built, the 850 Q-jet Edelbrock makes may be an even better bet if buying new.
  11. akbound
    akbound 1/2 ton status
    Apr 20, 2004
    San Antonio
    Both my vehicle have Quadrajets from Autozone on them. One has over 70k since it was installed. Little, if any tuning, required and will start right up after install. Best of all---CHEAP!!
    I did a quick search on their website for a '74 ELDO and this came up.
    CARBURETOR for a 1974 CADILLAC ELDORADO
    </FONT>[​IMG] Normal Stock[​IMG] Special Order[​IMG] Not Available[​IMG]
    ItemPart
    No.
    CHAMPION
    ROCHESTER QUADRA JET 2-1131 YR$20.00 $164.99 [​IMG][​IMG][​IMG] [​IMG]
    [​IMG]HOLLEY
    ROCHESTER MODEL 4MV 64-70641 YR$35.00 $199.99 [​IMG][​IMG][​IMG] [​IMG] O.E.M. #7043230, 7043232, 7043233, 7043234, 7043235,
    7044230, 7044232, 7044233, 7044234, 7044235,
    7044530, 7044532, 17054943, 17054945, (
    MORE...)
  12. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
  13. WantedaDodge
    Dec 16, 2004
    282
    Eugene, OR
    I haven't heard anything about those in real life, I don't anyone that has one. But they look good! I read a magazine article about them and it showed all the stuff they go through on them.
