Which radiator to buy???
Discussion in '1982-Present GM Diesel' started by 6.2Blazer, Nov 16, 2004.
  1. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    My '90 K5 is ready for a new radiator.........the original one is both rusty on the outside and pretty clogged up on the inside, including a few pin-hole leaks, so I don't think it can be saved by the radiator shop.
    Here is what I've found so far:
    radiator.com - 34"x19"x2" 3 core (the OEM one is 4 core!) for $354
    Autozone - 4 core (didn't list any other specs) $348 + tax
    Advance Auto - 34 x 19 1/4 x 2 5/8 4 core (Transpro brand) for $348 + tax
    Napa - $472.......yikes.........
    I'm calling some local radiator shops this afternoon.
  2. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Wow..that seems really high from radiator.com /forums/images/graemlins/eek.gif I bought my 4 core from them and only paid $123 shipped
  3. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    I thought so also.........was hoping they would be at least a little cheaper than the local places.
  4. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Was this a diesel 4 core?
  5. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    The IR4095 from AutoZone is made in Mexico. I asked for a rad for a 6.5 3/4T Sub and this is the one I got. $348. It fit in my K5 just fine where the gas rad was. The diesel rad is a lot wider than the gas model, and the brackets move over to the next set of holes. I punched some holes in the gas sheet metal for air flow, otherwise some of the rad is blocked. It has a built in engine oil cooler on one end, and the ATF cooler is on the other end.
