which ram for hydro-assist?
Discussion in 'The Garage' started by muddybuddy, Nov 28, 2005.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    hey there, im in the process of putting my truck back together, and want to do hydro assist while im at it. which ram's and what size are you guys running?
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,991
    130
  3. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    I run a West Texas Offroad hydro assist system, works great for me.
    j
  4. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    someone was talking about a 2.5" ram on pirate in that thread above, where could i find one of those? i know i want at least a 2", is it worth the extra $ to get a 2.5"? who makes one?
  5. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I can lift my truck with a 2" ram, no reason to go 2.5". I wouldn't recommend 2" for the street.
  6. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I run a 1.5"x8" stroke ram from Rocklogic. The shaft is bigger then WTO's and it doesnt leak :D Lines that came with the kit suck though. I ended up getting new lines and fittings from WTO.
  7. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Ow and I can turn my 42's with my pinky :D
  8. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    If you can get enough force out of a 1.5" ram, that's the way to go. Seriously, zipping down trails behind short wheelbase jeeps becomes a hell of a ride when your steering doesn't want to turn. If I give it a second to react I can lift the truck sideways with one finger on the wheel. But for anything higher than trail speed it's slow.
  9. big94gmc
    big94gmc 1/2 ton status
    Sep 1, 2004
    3,651
    No VA.
    I'd suggest finding yourself a 2x8 stroke ram....plenty of power for the assist you want to run, and when you decide to step up to full, you're set, 'cause that'll be enough.
  10. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    look into tractor supply rams. 2x8 ram 70$ ive never heard anyone have a problem with them. and it will work for hydro assist or full hydro
    also chief makes a 2x8 ram that is 50$ backyardbuilt runs one on this board. i dont know anyting about chief though. its about the same as the tractor supply i think
    if you want a double-ended ram wagoneer machine shop has them for 150$. seems pretty cheap for what it is.
    im probably gonna do the tractor supply ram when i do full hydro
  11. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Chief is a tractor ram from what I've seen. I picked mine up at the local farm store.
  12. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    He DD's his truck.
    2" ram is not good.
  13. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    x 18,000
  14. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    really? why would a 2" be so bad for a dd? seems like it would have more steering power than the 1.5" :crazy:
  15. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    It does but it has a slow reaction time.
  16. muddyblzr
    Nov 2, 2004
    623
    x3 it will provide more turning power but is too slow for steet driving
  17. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    so a 1.5 can move faster? what about a 1.75? thanks guys, im learning alot :D
  18. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    muddyblzr is right it is too slow. Imagine your on a icy road and you have to make some quick changes to the steering wheel, you better get it right on the first try, cause thats all your going to get with a 2" ram.
  19. muddyblzr
    Nov 2, 2004
    623
    one thing that you could do to make the steering quicker is find a smaller steering wheel. you lose some of your leverage but with hydro assist it shouldnt affect anything. might help turn quicker
  20. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Not if the ram refuses to turn. Have you driven a rig with a hydro setup? (not trying to be a dick, honestly asking)
    If you try and turn the wheel faster than the pump can deliver fluid to the ram, you're not turning anywhere. You've just gotta wait for the ram to catch up, it's just not possible to turn faster than the hydraulics are allowing you to.
