Which rod to twin stick?
Discussion in 'The Garage' started by tonto, Jun 1, 2003.
  1. tonto
    tonto Registered Member
    Feb 12, 2002
    50
    oklahoma
    I have a ford NP-205 to run with the R-cut 60 I have. The question I have is which shift rod to grind on? I looked on alaska offroad, he used a ford version. I pulled the shift rod closest to the adapter plate and it looked different than the ones in his pictures. So did I pull the wrong one, is it the one closest to the front output instead? Also what is the shift pattern as you pull the stick back from all the way forward, first 205 case that I have owned. Thanks for any help.
  2. XtrmChevy
    XtrmChevy 1/2 ton status
    Jul 14, 2001
    148
    Finland, Europe
    The one closer to the adapter I believe. The shift pattern will be from all the way forward: low-neutral-hi.
  3. jstevenj
    jstevenj Registered Member
    Aug 28, 2002
    94
    north Miss.
    I have some details on my site.
