which sawzall blades?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jekbrown, Dec 24, 2001.
  1. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    ok, i am FINALLY gonna get a recip saw. If I am gonna be cutting steel...some of it up to 1/4"...but most just body sheet metal, what kind of blades should I be using? Is there a special type or brand or ? Info appreciated...them fenders are gonna get chopped! =)
    Jason
    See the on-going build up of my '85 Jimmy! <a target="_blank" href=http://community.webshots.com/user/jekbrown>http://community.webshots.com/user/jekbrown</a>
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I use Dewalt blades or what ever else I can get ahold of. As for quick cutting 14 TPI (Teeth per inch) for soother cuts the more teeth the better. THe trick is not to go really fast, just go fast enough to keep the blade from binding. If you go to fast you will just destroy blades and it will actually take longer because you will heat treat the metal you are cutting.
    86Jimmy 4"&35"MTRs,87 burb 4"&33"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Make sure the length is correct for the cutting that you are doing. A blade that is too long will contact some other part and bend the &amp;^%$ outta that blade.
    THe hotter they get, the easier they bend.
    Never tried the DeWalt blades, but Black and Decker blades are nothing to write home about.
    I use 16 tpi most often.
  4. WinnipegK5
    WinnipegK5 Registered Member
    Aug 27, 2001
    66
    Winnipeg, MB, CANADA
    I use Lenox blades all the time and love them. For 1/4 metal I would suggest a Model 624R. Which is 6 inches long and has 24 teeth per inch (fairly fine)
    Merry Christmas
    Mike
  5. 1990K5
    1990K5 1/2 ton status
    Nov 6, 2000
    460
    LITTLETON CO.
    the milwaukee torch are the best hands down, i've worked at home depot for many moons and have spent many hours behind a sawsall, and thats my opinoin.
