Which shackle flip?
Discussion in 'The Garage' started by pismorat, Oct 22, 2005.
  1. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    Ok, I have decided to bite the bullet and buy, rather than make, a shackle flip for my p/u truck. I was looking at either the DIY one which requires new shackles, or the ORD one. Has anyone experienced trouble with the stock shackles bending or breaking? That is basically what is balancing my decision right now. Either use stock or new shackles...any opinions?
    Doug
  2. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    are you building a flexy truck or just to lift? if your going flexy, get the ORD flip and the 6" shackles together and the DIY flip and some longer shackles. if your just for lift the just stick with the ORD flip and your stock shackles. it will work just fine.
  3. pismorat
    Oct 29, 2002
    540
    California
    I am going for flexy, I offroad this thing more times than not. So its either ORD with 6" shackles or DIY with shackles? Thanks.
    Doug
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I would get the DIY flip. If you own a drill and a saw, you can make shackles any length you need.
  5. PsychoticDeadGuy
    Jan 8, 2005
    753
    good point. the shackles for the diy4x flip will cost almost nothing if you can cut and drill your own metal. the ORD flip requires a tapered shackle. hard to make perfect and cost alot more to buy. i did go the ORD route and made my own shackles with some old ones that were laying around. they work but not quite perfect. if ease of building i say go with the diy4x flip and homemade shackles.
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I would do the DIY flip or a SKY flip if you are going to buy one. Yes stock shackles can bend.
    Harley
  7. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    im with hossbaby50 on this one. diy flip and sky. diy bein the first choice because of the shackles. sky because its easier to adjust. ive got nothing against the ord flip though, im actually about to buy a used 2.5'' flip one.
  8. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    I would still just grind off the front spring hanger off of a parts truck and use that. Definitley the cheapest route.
  9. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    the DIY flip is the best one to date with respect to neat features. The backing plates with nuts welded to them is nice, and the ability to use simple plate shackles is a HUGE plus over any shack flip that uses factory style ones.
    j
  10. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
  11. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    The DIY Flip is the only one I have ever used, but I will vouch for the quality. It's top notch camparing it to all the other types of suspension components that I have used on other vehicles in the past. The shackle design and backer plates are great additions to an all business piece.
  12. mciahpv
    mciahpv Registered Member
    Jul 8, 2005
    97
    Gator Country
    I'm gonna step out here and vote for the ORD. I just installed the flip on my '86 along with their HD shackles and greasable bushings. Yes, there was a bit of wallet pain, but their parts and fabrication were top notch. Everything went just as they said, and they were mega helpful when I called to ask stupid newbie questions. One word of caution, the flip will move your axle forward slightly. ORD says that 3/4" is standard, but I'm running 12" springs and mine moverd forward approx. 2". Nothing you can't work around, but good to know if you're running big lift.
    I've never dealt w/DIY, but ORD and their crew is the best in my book...
