Which shocks for 4" lift? Rancho or Pro comp ?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Topdown, Jan 28, 2003.
  1. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    Which shocks for 4\" lift? Rancho or Pro comp ?
    Ok... now that I have finally figured out that I got the wrong springs for my lift, I figured out that I also got the wrong shocks for my lift. /forums/images/graemlins/smirk.gif I love this stuff! So, which shocks should I get? I currently have the RS9000's for what is apparently a stock truck. I like the adjustability of the shocks, but if there are better adjustable shocks for roughly the same $$ (or less - around $75.00 each) I would love to hear about it. I need some that will go with a 2 - 4" front lift and not reduce droop or stuff, like I need to tell you guys that! (I only need fronts, the rears are good to go).
    Anyway, all opinions welcome! /forums/images/graemlins/thumb.gif
    -Ryan /forums/images/graemlins/k5.gif
  2. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Re: Which shocks for 4\" lift? Rancho or Pro comp ?
    Depends entirely on your spring setup. I can tell you that the Skyjacker Softride 4"/6" lift is so soft that the RS9000 is too soft in compression for those springs. A slightly stiffer spring setup could use the RS9000. Rancho supposedly has a new version of the RS9000 that is adjustable for both rebound and compression (the original RS9000 is only adjustable on rebound), so it might work with the softer springs.
