which traction device?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by evil bastard, May 28, 2000.
  1. evil bastard
    evil bastard Registered Member
    Mar 14, 2000
    18
    central wa state(yaakima valley)
    been looking at the new version of the lock right for my 74 12 bolt. was wondering if anyone had any of these. has anyone installed a traction device(s) other than a full detroit? im running 35s, 70% on road use, 2-3 months of snow/ice a year. hope this info helps.
  2. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    I have the detriot ez locker in my 12 bolt.It was cheap and did'nt require the axle to be reset up by a pro.I have had good luck so far.I put it in over a year ago in a '77 Sub.now it is my blazer.I run 33" tires for now.It survived when the pinion bearing went and ate the housing and gears.I built another 12 bolt with the same locker and carrier but with new gears and bearings.I would recomend It.Brady
  3. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    I ran an ARB front and rear for 3 years and loved themI now have a detroit in back as with the doubler the ARB will not take the tork with the 6000LBS that blazers are. ARB did send me a new 12 bolt locker that needs a home!
  4. SnakeEyes
    SnakeEyes Registered Member
    Apr 18, 2000
    37
    Colorado
    Ok Evil, nice name, having a locker on snow and ice can present a challenge as the torque gets continually passed back and forth between the rear drivers. It can screw you up and throw you into the ditch faster than you can open your next beer. HOWEVER having said all that , If you are aware of the operating parameters of the locker and are prepared to deal with them, run a locker by all means. I can't comment on your particular choice as that is not what I have experience with.
  5. Bigd
    Bigd 1/2 ton status
    Apr 3, 2000
    399
    Co,Colorado Springs
    Had a lock-right in my 12 bolt.Completely grinded the teeth in the side gears down.And yes it was properly shimmed and installed.But i had 36 inch tires.I have known other people too have no problems at all.I would say try one but save the stock internals just in case.
