Which tranny and transfercase should I go with?
Discussion in 'The Garage' started by blazindorito, Feb 11, 2005.
  1. blazindorito
    blazindorito 1/2 ton status
    Nov 25, 2003
    2,047
    Southern California
    Which tranny and transfercase should I go with. I currently have a turbo 350. Should I rebuilt mine or rebuilt a turbo 400? or what else should I do? I currently have a rebuilt 350, d60, 14bff w/ detroit locker, 6" lift, with 37's on a 16" rim. Automatic. Want to stay automatic. I want to be able to eat, drink and still change the tunes at the same time w/ out having to worry about changing gears.
  2. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    700R4 will give you a lower first gear and OD for hiway use. Th350 is fine for normal use and would seem to be cheapest since you already have one, Th400 is the workhorse, very HD. Just depends on how much $$ you want to spend and on what your goals are. Always go with a NP205 T-case, cast iron case, gear driven and bulletproof.
  3. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Sounds like you're already pretty heavy duty with that running gear. I'd go with a sm465, but if I HAD to keep it auto, I'd go with a 400. No question on the 205.
  4. th 400 and np205
    holla!
  5. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    ditto and exactumundo... I had the turbo 400, np203 setup with a b&m shiftkit.. once I went to the SMC465 and NP205 I will never go back...
    the only thing im thinking of doing is a NV4500 instead... changes the gears around and adds overdrive
  6. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    What is first in a 4l80?
  7. folkenheath
    folkenheath Worthless Trash Premium Member GMOTM Winner
    Nov 12, 2004
    4,269
    159
    Wisconsin
    2.48:1, same as a TH400
  8. RootBreaker
    Nov 29, 2001
    5,117
    173
    first is 2.48???? SMC465 is 6.55:1 second is like 5.something:1 then the problems start.... 3rd is 1.71:1 I think... then 4th 1:1..
    the nv5600 gets rid of the 6.55:1 makes L= 5.something and then gets rid of that huge gap between second and third... :grin:
  9. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Hmmmm, think I will stick with the 4l60 for the 3.06:1 if I go Vortec...
    Thanks.
  10. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    sm465/NP-205
  11. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    TH400/205 if avail, if not th350/205...extra clutches and shift kit, can't go wrong.
  12. eclipse
    eclipse 1/2 ton status
    Jan 1, 2005
    1,245
    Sparks, NV
    SM465/np205.... I can eat, drink, change tunes and shift no problem. :D
  13. RootBreaker
    Nov 29, 2001
    5,117
    173
    the bottom of beer cans have the bump in them for the shift knob :grin:
  14. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    My dad had a th400 in his 3/4 ton 74 chevy van and that thing pulled our 11,000 pound houseboat without breaking a sweat. Also after about 5 years of use on it my brother was driving home at night while i was in the passenger seat and while he was trying to find N in the dark doing 55 he kicked it into reverse! It sqealed the tires for about 30 feet and dropped back into D. Kept on ticking with no problems until the day we sold it.... got to be the only tranny i've ever heard to hold up under a 55 mph reverse shift.
  15. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    yeah, the TH400 is ungodly beef. What a monster. If built correctly, you can beat the living snot out of them and they will suck it up. My tcase is a 205, nothing but good things to say about them.
    Tranny-wise, I run a 700R4. It has good gear ratios with 1st and OD and if you keep them cool they will last for a while... but my looong term plan with my rig is TH400+klune+np205.
    j
  16. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Sounds like it's time to upgrade to a built TH700R4 and 241 case. :D I favor the 241 over a 208, 203, and 205. It has the best low range, is the lightest, lasts for a long time, and is plenty strong for 99% of the street legal rigs around.
    Of course if someone could adapt a 271 from an HD dodge cummins that would be the ultimate from a stock vehicle IMHO, low range like 241 and stronger than a 205.
  17. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I don't know about that, I watched SeattleK5 break the tailshaft off of his K-Case 400 on New Years and he wasn't even close to being hard on it.
    As far as a recommendation, I would say it depends on what you do w/ your rig. For a trail rig, or even a rig that is a driver but sees VERY REGULAR trail use I wouldn't recommend anything but a manual tranny of your choice. I just don't like the idea of loosing a couple quarts of a/t tranny fluid leaving me stranded someplace:screwy: ... and w/ a manual you can roll it down a hill and get er' started if your battery dies for some reason.
    If it is a street driver, then automatics are handy and nice and all... but just not near as fun...:grin:
  18. big4x4ride
    big4x4ride 1/2 ton status
    Feb 11, 2004
    216
    Corpus Christi, TX
    Im in the middle of pulling my 700r4/np208 and going sm465/np208
  19. captaininsano
    captaininsano 1/2 ton status
    May 4, 2004
    233
    Bay Area, CA
    I just swapped out my TH350 / np203 combo for a SM465 / np205. I personally hate automatics and am so happy to be rid of automatic transmission fluid. I have had so many autos grenade on me. Never once have had a manual go out even after severe duty. :D
