Which tranny cooler?
Discussion in 'The Garage' started by K1Orion, Feb 25, 2003.
  1. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    Those with 700r4, what cooler do you run and how much $?
    Where did you get yours? /forums/images/graemlins/1zhelp.gif
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I run an 18,000 GVW stacked plate cooler made by Long Inc. There was a bigger model available, but it didn't come with any of the fittings needed for the install.
    If you are looking at buying a tranny cooler, stay away from the old tube/fin design. They don't cool as efficiently and aren't as durable.
  3. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Search here I used an 11" x 11" cooler from this vendor on my Sub.
  4. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    the best cooler as far as technology goes, has to be the B&M. It is stacked plate like a radiator and can be had for around $50 from Summit Racing for the 24,000# cooling capacity.
    Just my .02
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Just go with the biggest stacked plate type you can find. The tube and fin type are not as efficient and weaker.
  6. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    [/ QUOTE ] Click here for the cooler and pricing
    John
  7. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I have a B&M stacked plate cooler for my trans fluid and one for my engine oil. The B&M super cooler is the biggest one they make.28000 GVW Cost around 60.00 They work good.
    BTW. Longs coolers and B&M are exactally the same. Longs makes the coolers for B&M up in Canada. But its easier to find the B&M down here in the U.S.
  8. Can Can
    15,552
    136
    I was pretty sure I heard that somewhere before- my Long cooler is EXACTLY the same as my buddy's B&M.........
