Which type fan to use?
Discussion in 'The Garage' started by roostr3269, Apr 21, 2002.
  1. roostr3269
    roostr3269 1/2 ton status
    Jul 2, 2001
    305
    michigan
    Well, i will be getting the Jimmy back Monday with the radiator and gas tank installed. I was going to go with a straight fan, but now i am hearing that i should run a clutch fan. Also i was told, if not a clutch type mech. fan, then i should go with an electric fan setup. It seems like anyone i talk to has a diffrent answer. I'm just not sure about running an electric fan because of mud and sand causing it problems, but i like the idea of getting full air flow at lower speeds. any ideas? Thanx in advance. p.s. Running a reverse rotation water pump.
  2. 1BAD88
    1BAD88 Registered Member
    Feb 23, 2002
    89
    bristol ct
    I am running a direct fan with a 160 degree thermostat and never had a problem with that combo in the heat. When winter hits I just pop in a 190 thermo and it gives me plenty of heat.................
  3. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    If you are running a reverse rotation water pump make sure you use the reverse rotation fan as well or you will have overheat troubles.
  4. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    I am going to go with two thermo controlled 14" electrics with shut off for water crossing... someday /forums/images/icons/frown.gif
  5. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    i was told the a <font color=green>green</font color=green> on will boost your horse power.....
  6. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    I am in the process of moving over to electric also since I am doing water crossings. If you go electric try and find a F#*d Thunderbird or Lincoln Mark VII fan. They are about 20" and have a built in shroud and two speed drive.
  7. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    What about having a electric pusher fan in addition to a mechanical? I am thinking about this for my truck. I heard that its hard to beat the air flow you get with a mechanical fan, so I am weary of changing over completely. Also have had battery issues before and a mechanical needs no power to run.
