Which Ujoint did you guys use?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Jersey, Dec 27, 2001.
  1. Jersey
    Jersey 1/2 ton status
    Aug 14, 2001
    234
    NJ
    I put a Dana44 out of a '70 K20 in the front of my '91 K5 and i'm trying to connect my stock driveshaft to it. Just can't figure out which ujoint to use. Stock 1/2 ton joint doesn't fit in D44 yoke - caps too large in diameterv and too wide to fit between ears on yoke. any help? Thanks.
    - Jersey
    '91K5 - 350, 700R4, NP241, 14BFF/Dana44, FlowMasters, 4" & 35x14.50's on Welds
    <a target="_blank" href=http://community.webshots.com/user/len1313>[/b]PICS[/b]</a>
  2. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    This isn't a direct answer to your question, but it should get you on your way. The first thing is, you have to find a counter person that is willing to help you with your search. Next, you take your stock application, get the U-joint cup size. Usually a 1310 I'd think, and then take the application of the front axle and get ITS U-joint size and then use the catalog and cross them and find a U-joint with a cross that fits the Driveshaft, and the other that fits the Axle. I'm sure you are looking at something like a 1310/1330 or 1330/1350 something like that. Those aren't part numbers, just actual sizes. Your application may differ.
    Best of luck,
    Corey
    88K5
    [​IMG]<font color=red>Girls Like Guys In Bow Ties
    <a target="_blank" href=http://www.geocities.com/corey_perez>http://www.geocities.com/corey_perez</a>
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Its usually the Napa 447 or Napa 348. I used the 348 for my rear driveshaft (stock '79 to 14B) and the factory one for the front. One of those should do it. Pick up both and return the one that doesn't fit.
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com>www.blazzinor.rockcrawler.com</a>
  4. Jersey
    Aug 14, 2001
    234
    NJ
    Thanks guys. appreciate it much. hopefully i'll find someone behind the counter that actually has some mechanical ability and knowledge. Some of the guys (kids) cant tell a ujoint from a head gasket! thanks again.
    - Jersey
  5. denver75k5
    denver75k5 1/2 ton status
    May 15, 2001
    1,017
    Somewhere In The Woods
  6. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    if the "stock" one didnt fit i am wondering if that is the small ?260? size (sorry cant find my u joint book right now)
  7. michaelm
    Feb 2, 2001
    872
    man i am an idiot
    I scanned all that info a while ago and it is posted
    <a target="_blank" href=http://www.customtruckshowcase.com/forum/showthread.php?s=&amp;threadid=183>http://www.customtruckshowcase.com/forum/showthread.php?s=&amp;threadid=183</a>
    sorry if you have dial up, I didnt compress them and they are all on 1 page
  8. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Link is asking for username and password.
    Houston, TX
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    so register
    formerly 77chev
  10. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I went to O'Reilly's and the guy there was real helpful. Measured the yokes with a micrometer and looed it up i nthe book to figure out what I needed. Like someone said, just gotta find a good parts guy.
    90K5
  11. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    1970 uses a small 260 spicer u joint
    it is a 1310 with smaller caps then the regular 297 joint.
    1.063" vs 1.188"
    formerly 77chev
