which way is forward (springs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by coopertwpk, Dec 10, 2000.
  1. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    which way is forward on rancho springs the double clamped side?or single?
  2. Grim-Reaper
    7,385
    Atlanta
    Double. That end also runs a larger bushing and eye if you look. Do me a favor and e-mail me when you get them on and tell me if your driveshaft is too long.
    Diging it in the dirt with my K5's
    Grim-Reaper
    http://grimsk5s.coloradok5.com/
  3. coopertwpk
    Mar 18, 2000
    478
    On 88 and newer the front and rear bushings are the same 9/16 thats what confused me so i replaced the bushing and installed them backwards great huh.should I turn them around?
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    the springs should go either way. they have the center pin teh the exact center, si they should be OK either way
    90K5
  5. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    I know you said Rancho, but my skyjacker springs can go either way. However, Grim didn't seem to hesitate with his post. I'd go with what he said. Did they not come with instructions? Mine told me they could go on either way, except for the back, then it said put the think end of the shim in the back. Should say in the directions, that is if you have them. If you dont feel comfortable with our info, just call or E-mail Rancho.
    I miss my Ex, but my aim is getting better!
    http://mccordhouse.freeservers.com
  6. Grim-Reaper
    7,385
    Atlanta
    Uhhhh might want to. Thinking about it on mine the one clip is on the 3rd leaf keep the front from fanning out. Since that one is towrds the back it may fan out under full droop and be catching junk like branches or worse yet stab into a rock. Did not know that 88 ran the same size spring eye both ends. Mine runs a larger eye at the front. Yes the pins are dead center so axle should be the same location. I found that my STOCK driveshaft is to long with the lift It bottoms out. Figure that one out!
    Grim-Reaper
