Which way to go?
Discussion in 'The Garage' started by homie77, Aug 9, 2002.
  1. homie77
    homie77 Registered Member
    Jul 23, 2002
    14
    Soutn Texas
    Thinking of going with 8in rear springs or 4in rear springs and shackle flip. What do the members of CK5 think? All comments welcome.
  2. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    i'd say if you going to tow...go with the all spring
    if not the 4 inch with shackle flip will flex much nicer
  3. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    Me thinks that you better buy stock in "Spicer"...as in U-Joints.What size tire are you planning on running?That's alot of lift.....hence alot of mods!But if you are dead set on the amount of lift,I'd go with the shackle flip and 4" lift springs.There is another plan or two.You could use a 1 ton shackle mount(gives about 5" lift),extended rear shackles(Desert Steel..2" lift),pair of "Zero Rates"(1" lift).This should give a nice soft and flexy ride.Mike
  4. mplogic
    mplogic 1/2 ton status
    May 7, 2002
    263
    Phoenix, AZ
    Yea, that's a ton of lift for a short wheelbase vehicle. In a pickup, would probably be no problem but that rear driveshaft is going to cost you a small fortune and those extreme angle cvs have limited life expectancy and usually not freeway driveable. Unless you are going to throw some rockwells under it... /forums/images/icons/smile.gif Any spings over 6" get very stiff and your off-road performance will actually decrease (unless you are building a mud truck or something just for show). What tire size do you want to use? If you are dead set on 8" I'd say have some dropped front mounts fabricated and use 6" springs in the front and the shackle flip with 4" in the rear. That will still give you some flex.
  5. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Number one question is what all are you going to do with the truck? Any towing?
