which welder?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Nonesuch, Sep 11, 2001.
  1. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    I already have a Lincoln arc welder but i am looking into buying a mig that is smaller and a little easier to use. I burn everything up with the arc! what brands of welders are good quality and not too expensive. somebody on here is using a under the hood set up that sounds nice. are the harbor frieght welders any good?
  2. tyler t.
    tyler t. 1/2 ton status
    Aug 7, 2000
    163
    I would go with a miller or lincoln considerg theya re pretty much the same. Something in the 125-135amp range will do pretty much anything you need to do. If you are intersted in the premier power welders let me know I just became a distributor for them. They are a little on the pricey side, but they now have attachments to do mig and tig welds as well. Let me know.
    J:(P it's what's for dinner!
  3. Gold Rush
    Gold Rush 1/2 ton status
    1,498
  4. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    I bought a Chicago dual mig welder from Harbor Freight for about 250. a year ago.
    1984 K-5
    4" lift
    35x12.5 MTs
    buildin a 400 for it, any info greatly appreciated
  5. TwoCrowsDesign
    TwoCrowsDesign 1/2 ton status
    Jul 13, 2001
    387
    I have a Lincoln sp100t, I think its the smallest one they make. My only complaint is the amperage dial has only 4 positions, the next model up allows infinite control through the power range, which is really useful for getting the perfect bead dialed in. It works great though and I really like it for the price ($450).
    John
  6. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    Hobart 135 Handler, 110volt, w/wo gas, very adjustable, about $500
    Michael[​IMG]
    <a target="_blank" href=http://www.jmartin.net/parker/goose.htm>www.jmartin.net/parker/goose.htm</a>
  7. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    500 for a 110 volt? Sounds a little high to me. My Cebora 220 was 640 brand new. It puts out about 150 amps. Thats hot enough to do just about anything up to 7/16 material.
    <a target="_blank" href=http://www.daytonamig.com>www.daytonamig.com</a>
    "you know... the guy with the BAD A$$ spring perches!!![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  8. JoeAngelicchio
    JoeAngelicchio 1/2 ton status
    Feb 18, 2000
    628
    South Central Ontario, Canada
    How do you like the Hobart?
    <font color=green>Joe Angelicchio
    <a target="_blank" href=http://community.webshots.com/user/jangelicchio>http://community.webshots.com/user/jangelicchio</a>
    Lisle, Ontario, CANADA</font color=green>
  9. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Okay Justin.. holding out on me.. now I know you can weld. you're in trouble.. lol..
    I haven't failed, I've found 10,000 ways that don't work. www.rocko.rockcrawler.com
  10. Alex
    Alex Registered Member
    Jun 19, 2001
    78
    Northern California
    Nonesuch, look for a welder that can weld sheet metal and semi-thick bar stock. I use a Lincoln 130 mig, w-w/o gas, 220v, 30% cycle. This one gives me the range to weld thin sheet metal and up to 3/8" stock. Anything thicker and you'll need your arc welder. Try to stay with a 220v system they're more efficient.
