Which wire is the tach lead on a 1990 350?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shum1, Jan 3, 2001.
  1. shum1
    shum1 1/2 ton status
    Oct 8, 2000
    270
    UTAH
    I'm putting in an aftermarket tach. The instructions just say to connect to the neg coil terminal. My haynes is vauge. Also, I'm not sure what type of ignition mine is. Ive heard people call it HEI but on mine the coil is mounted on the intake not on the dist. cap like the ones I see in the mags. Thanks..
    <P ID="edit"><FONT SIZE=-1>Edited by shum1 on 01/03/01 07:50 AM (server time).</FONT></P>
  2. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    on HEI dist there should be a terminal (next to the power in)that says "tach" That would be the one to use, but you need a plug to get it in the case.
  3. His truck should have the later model dist in which uses an external coil.My 88 truck had a pig tail for a tach in the harness next to the coil,its the black wire on the plug that goes to the coil.If your still not sure turn the ignition on and use a test light to see which has power,the one that does'nt is the one you need.Good luck
  4. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    My 89 and 87 both has had a wire with connecter coming off coil. This is for the tach. Your ignition is H.E.I.
