which wires to fuse box/starter????
Discussion in 'The Garage' started by 01maroonz71, Apr 18, 2007.
  1. 01maroonz71
    01maroonz71 1/2 ton status
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    ok, i've looked at wiring diagrams like crazy....but i can't figure this out. i have a 1987 project truck that originally had TBI(harness has a TON of connectors) and im about to cut all that crap out of there...but i can't figure out which wires i need to hook up the ignition, and to make the lights run.
    basically,out of the wires coming out of the fuse box(inside engine bay), which wire do i hook to the battery to give the fuse box power???
    and which do i hook to the starter so when i hit the key, it gives the starter power???
    the lights are still wired up, as is the oil pressure sender, and the temp sender. i pulled the ECM wires out since they were just getting in the way. i don't believe that i need them do i????
    thanks alot guys!
    ~Dave
  2. mrdrinksalil
    mrdrinksalil 1/2 ton status
    Apr 4, 2005
    1,595
    Atlanta, Georgia
    My ignition wire to the starter in my 82 cab is purple (10 gauge wire i think). And I have two power wires into my fuse box (both red and 10 gauge i believe), I think one is supposed to come from the alternator but I have a high output one wire alternator and ran it straight to the battery.
  3. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    yup, 2 10 gauge feeds.. 1 from the alternator, the other from the starter, via the junction block on the firewall above your driverside valve cover...
  4. 01maroonz71
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    awesome guys...both your replys are kind of conflicting. so ill run the 10gauge purple to my starter, then the 2 red 10gauges from battery for now(no alt) thanks again guys!!!!
