Which would you use?
Discussion in 'The Garage' started by onlychevy6, Nov 29, 2006.
  1. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    Say you have a 75 k5 with a 350. So you do not have to smog it. Would you go with a full length header or a shorty and why?
  2. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    long-tubes, they give better performance
  3. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    Full length headers are better but you will have to redo some of the exhaust to get them in there and you may have fitment issues with the spring shackle or the front driveshaft. Shortys will bolt right in.
  4. TheAustrian
    TheAustrian 1/2 ton status
    Jun 20, 2006
    160
    Austria
    I have long tube headers, had a complete new dual exhaust system installed, so I had to rework it anyway. The flange is very close to the front shakles, but it works.
  5. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    In all around workability, I like shortys. Makes the starter easier to get to, and just less hassle all around.
  6. TheAustrian
    Jun 20, 2006
    160
    Austria
    not good picture but visible
  7. onlychevy6
    Mar 29, 2003
    1,293
    Hockley, Texas
    i currently have full length headers that were originally smog headers. The holes were plug filled(and now have a real bad exhaust leak). And yes the flange touches the shackle bolt. I have to get a new exhaust done. because it is too close to the floor and gets so hot your shoes stick to it. I measured the temp with a fluke heat detector and it said it was 264 degrees next to the trans tunnel and just 5 inches away it was 200 degrees. Currently my exhaust is a 3" system. And dumps out right under the front seats. I am going to swithc to a 2 1/2" system and was thinking of changing headers also.:crazy:
    Forgot to mention i also run dual exhaust.
  8. broke73
    broke73 1/2 ton status
    Apr 12, 2005
    109
    Grand Blanc, MI
    Shorties, Long tubes always seem to leak at the heads.
  9. TheAustrian
    Jun 20, 2006
    160
    Austria
    264 degrees?? Celsius or farenheit? I have no carpet inside, will roll it with protectakote. Hope this will not be a problem? If it gets too hot, why not stick a heat shield on the underbody where it is close to the headers?
  10. onlychevy6
    Mar 29, 2003
    1,293
    Hockley, Texas
    Farenheit. I plan on getting some carpet but with that type of temps i am affraid it will catch fire. I had a beach towel on the floor and it literally burnt a hole about the size of your fist through it. :doah:
  11. TheAustrian
    Jun 20, 2006
    160
    Austria
    this is 130 degree celsius, still damn hot!! But I think using some kind of a heat shield (foil) whatsoever should minimise heat comes to the floor.
  12. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    I currently have full length headers and I am going to go with some shortys pretty soon. Every one I have talked to and every pic I haev seen with full length headers on our trucks they always seem to either lay on the shackle or come very close to the shackle. Mine hit when I first got them but a little clearacing later and it all fits. But I still am unhappy with the fitment hence my reason for wanting shorties. Long tube headers are better for low end torque but I will sacrifice the little low end power I may lose for better fitment and clearence under there.
  13. MaxPF
    MaxPF 1/2 ton status
    Apr 13, 2006
    2,207
    Chandler, Arizona
    I run good ole cast iron manifolds. Why? Because I have a stock motor and they don't leak :wink1:
  14. garlicbreath
    May 17, 2003
    1,136
    Denver
    Thats what i have too, a set of rams horns. Never had a gasket issue yet, and they have been on there 10 years.
  15. MaxPF
    Apr 13, 2006
    2,207
    Chandler, Arizona
    I have the stock wheezer manifolds that came on my blazer. When I build a new motor I will either use late model Vortec exhaust manifolds, or I will fabricate a set of headers. Stainless u-bends + 3/8" flanges + tig welder = custom headers that fit and dont leak :saweet:
  16. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    X's 2 on that. I did have mine leak a few times but I now have that fixed.
  17. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    mine leak when the bolts loosen up. lately Ive been having a problem with the header bolts loosening from the head and I have to check them every few days. I also have the problem with the shackle and driveshaft clearance. Its been mentioned here before and Im going to look into running chevelle headers. they are suppose to fit and give much better clearance.
  18. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    Ceramic coated full length. Buy a good pair, like thorleys, dougs, hooker, hedman, etc. Get full duals, there are kits available or find a muffler shop. Shorties are good, but you are going to lose some torque compared to a full length design. I would definately go coated. Get the correct set for your truck without AIR tubes and run without cats.
  19. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    I have stock manifolds and soon I am going with a set of shorty hedmen headers i got for $30. All I ned is to go pick up a gasket and bam I got some shortys and tru dual 40s.
    I was gonna get full headers but was told buy alot of shops about the whole leaking and bad clearence thing so I got some shortys.
  20. garlicbreath
    May 17, 2003
    1,136
    Denver
    Another trick to prevent leaks and loose bolts is to get 2 sets of gaskets, and soak them in a bucket of water for 30 minutes before putting them on, put 2 on each side, then start the truck and warm the motor up, then retighten the bolts.
