which years are best?
Discussion in '1982-Present GM Diesel' started by 3car, Aug 3, 2003.
  1. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    i was thinking about selling my 91'gas blazer and getting a diesel.are any years better for the 6.2 than others?anything to look out for?
  2. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    yea i recomend 1985 and up as the earlyer 1 had more problems head bolts & theromstatic controllers for starts
    i really like mine good luck on your planed purchase
    Randy
  3. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    82 and 83 had the head cracking problems, also the heads have different threads (course or fine cant remember which is which though) on the injectors. So as the doctor says go with one over 85 and clear problems.
  4. 82diesel
    82diesel 1/2 ton status
    Jul 2, 2003
    316
    Stockton, CA
    great
    Were the cracked heads from a manufacture screw up or were people destroying them by not taking care of the engine?
  5. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    Prolly from peeps pushing the engine too hard while towing I'd imagine.
  6. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    Im pritty sure it was a defect. Cant remember though.
  7. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    Cracking heads is something to watch on all, even the 6.5s. In '97(some late '96s) GM went to a higher volume water pump and dual t-stats for improved cooling. Best year for the 6.2 motor, IMO, the '92-93 versions. Supposed to be the same block casting as the 6.5s, just smaller bore. Blocks are said to be thick enough to handle an overbore too 6.5L displacement.
    I wouldn't pass up a clean pre-'85 blazer/sub just because of the year. Most stuff can be upgraded easily to the post '85.
