while driving, blazer cuts off...Monday Update
Discussion in 'The Garage' started by 3bowties, Jan 28, 2006.
  1. 3bowties
    3bowties Registered Member
    Jan 28, 2006
    5
    N. VA
    :D Driving down the road, @25-30 mph, with little throttle, my K5 cuts off. it sat for three years before i bought it. i changed all the fluids and just got it street legal today. Then, with a new battery, the lights dim and it just turns over. almost in slow motion. with lots of smoke by the starter and a definite electirc smell...HELP
  2. 3bowties
    Jan 28, 2006
    5
    N. VA
    also, blazer is still stock......for now
  3. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    check the fusible links and maybe pull the starter to have it checked, might be drawing too many amps....good luck
  4. Big Truck
    Big Truck 1/2 ton status
    Feb 19, 2005
    129
    hermiston, OR
    I'd check and clean the cables at the battery, starter and ground.
  5. Big Truck
    Feb 19, 2005
    129
    hermiston, OR
    You can also take the starter out have it checked at the parts store.
  6. 3bowties
    Jan 28, 2006
    5
    N. VA
    i got a new starter today for some hauling i did to the dump, hey plus a new corsa exhaust system for my dually.. i will switch the starters out tomorrow. hopefully that will stop the smoking also.....this sucks...i hate when the stuff breaks at night and you have to wait till the morning..
  7. K5-newf
    K5-newf 1/2 ton status
    Nov 5, 2005
    236
    canada
    the problems sounds like my atv new battery dimmed lites and hard to turn over but after a while with the high beams on it melted the fuses and i bought a bigger fuse in it and worked fine and my bike smokes due buring oil check ur oil just in case
    Jason
    "keep on truckin"
  8. 3bowties
    Jan 28, 2006
    5
    N. VA
    Starter Problems....
    :confused: :confused: i tried a new starter today, actually all day...hah hah. i tried shimming it every which way to Sunday. i tried to get the trans inspection plate off, but the guy who owned it proir was nice enough to strip most of the bolts.....it just makes a continous clicking sound, even put a fresh battery in. is it possible for the starter to be new and bad?:confused: :confused:
  9. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    It sounds like one or both of your battery cables are almost done. A new (or reman) starter should have cranked fast with a good battery. Only cables left to check.
  10. 3bowties
    Jan 28, 2006
    5
    N. VA
    got her fixed, atleast the starter anyways
    i bought another starter, returned the old one and bought new battery cables. hooked it all up and now she starts like a champ.thank you all....but it still cuts off driving.....who cares though...atleast it starts so it can cut off.one thing at a time....
