whine\howl coming from rear end
Discussion in 'The Garage' started by Riktar, Aug 28, 2003.
  1. Riktar
    Riktar Registered Member
    Mar 28, 2003
    22
    Neosho, WI
    whine\\howl coming from rear end
    I have developed a nasty noise coming from the rear end that can be easily heard at speeds above 25 MPH under load amd gets louder just before you completely let off the gas.
    I can actually make this thing louder (More "whine" rather than "howl") when I slightly let off the gas. The "howl" noise is similar to the noise you would get from a manual tranny that is in reverse, or rather from running some big open tread tires, or maybe somewhere in between.
    Any ideas? Front pinion bearing? I can't seem to generate any play from the rear U-joint or the yoke on the rear end.
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Re: whine\\howl coming from rear end
    check your fluid? Did you recently have gears setup?
  3. Grim-Reaper
    7,385
    Atlanta
    Get the wheels off the ground and pull the drive shaft. Check the pinion for play. If you can't feel any it's time to pull the cover and see what's up. Check the back lash and gear pattern. sounds like it's starting to come appart
  4. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Sounds like the ring & pinion is wearing. Check the backlash and pattern.
  5. TheLakeRat
    TheLakeRat 1/2 ton status
    Nov 29, 2001
    363
    San Angelo, Republic of Texas
    Start saving your pennies. cause you going to be buying some new gears. CAuse if it is already howling that bad you will HAVE to replace them. Sorry /forums/images/graemlins/frown.gif
  6. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    i just checked on the same thing on www.ringpinion.com(ramdys r&p) and it sayd that it is bad pinion barrings.i have to replace mine this weekend cause i think i have the same problem
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Sounds like pinion bearings to me too. Mine screamed real loud for a couple months, then exploded and destroyed a lot of parts (the entire rear axle). That's when I finally gave up on 1/2 ton axles.
  8. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Time for a rebearing!!
  9. Riktar
    Mar 28, 2003
    22
    Neosho, WI
    Ok now I am really PO'd. I decided to check the fluid level to start with and since I couldn't feel any fluid near the fill plug I thought I would put some in. After I started putting in the SECOND bottle (1 quart size) I realized that the rear end was probably run dry.
    To further add to my enjoyment I was treated to the view of the stinking stuff making it's way out from the backing plates as well as front carrier bearing seal after a quick (less than a block) test drive to see if the noise subsided.
    About the only thing that did change from filling the thing up was a bit of a reduction in noise. As in the whine noise I was getting when I lightly backed off the throttle is gone. The howling under load is "slightly" quieter but still there.
    I don't even want to get into the fact that I should have been more observant about this since the individual I recently bought this from mentioned he just got done doing rear brakes and changing the axle seals on the rear. Since most of the other stuff on this thing were not represented accurately by him I should have just gonr through the Jimmy with a fine tooth comb.
    So now I guess it's time to crack the back cover, pull the brake drums off and see just how much damage was done. The way things are going I will probably find the lock screw broken off in the pinion shaft. That's probably how far things went in the prior repair.
    I wonder if it wouldn't just be easier to find a replacement 10 bolt rear end that I know has good brakes and seals and just swap out this mess.
    IF by some chance I do find that the only (Excluding the axle seals/bearings of course) source of damage was to the front carrier bearing maybe I could get away with changing that and be ok. I have never attempted one of those and was wondering if the front bearing/seal can be changed on the vehicle. As in: Is the front carrier bearing pressed on? Do I have to recheck the pinion/ring clearance?
