whine
Discussion in 'The Garage' started by Guss, Feb 28, 2005.
  1. Guss
    Guss Registered Member
    Feb 6, 2005
    78
    houston
    gear noise
    just replaced carrier and pinion bearing in rear. still have whine even with proper preload and backlash. could the pinoin depth still be off?? the gears where all in good shape, im lost:confused: :confused: :confused:
  2. Guss
    Feb 6, 2005
    78
    houston
    gear noise
    bump
  3. dyeager535
    26,979
    What did the gear marking compound tell you? IIRC, thats how you tell if pinion depth is correct or not.
  4. Guss
    Feb 6, 2005
    78
    houston
    it was in between the heel and toe leaning slightly on the toe side should i shim it more to the middle? noise goes away when ive got a good load on it, but under slight load like cruising its pretty loud.
