whining noise???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NEK5, Feb 2, 2006.
  1. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    tonight on my way home from work i notice a whining/whistling type noise that got louder when you accelerated and when u come to a stop and continues to do it while idleing
    any ideas...
  2. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    turn up your stereo or get bias tires :wink1:
    probly carb air intake or not sealing right or belt loose... stick your head in the engine compartment while its running then start putting your hand on things to seal
  3. sweetk30
    Nov 1, 2004
    25,529
    527
    horseheads , ny 14845
    flip the air lid back over to stock .:D
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    If its the 89-91? K5 in your av you are talking about. Check the Throttle body base gasket. They leak and make a nice whistle when they go bad. Also can cause some idle issues.
    Vaccume leaks? Check all your vaccum lines ect
  5. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    that might be it because i do have some idle issues...i will check that out and the vaccum lines
