Whining noise...
Discussion in '1983-2005 S-Series models' started by OFFRDK5, Dec 29, 2002.
  1. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Wondering if anyone else has gotten a whining noise from their 4x4 front end? I checked the fluid and it is good and full. The noise goes away after I put it in 4x4, drive forward a bit, take it out of 4x4 and back up. Sounds like a hub problem, but I don't see a nice place that I can take some screws out and put some manual hubs in!!
    Any ideas?
  2. Ck1500
    Ck1500 1/2 ton status
    Feb 8, 2001
    198
    Burton, Michigan
    may seem like a dumb question, but what fluid did you check???? front IFS Diff??? or Trans ??? or Transfer case??? or all ??? just curious cuz , mine made a whirring sound, only to come and find out that my front IFS puked all the fluid outta it, so i fixed the leak and put in more fluid and everything is grand now??? i guess my next question is when was the last time the fluid's were changed??? just curious hope this helps
    and btw there isn't any way that i am aware of installing manual hubs on a IFS S-10 truck,???? i think thats only for the Solid Axles, and if you were having troubles with hubs they would kinda make a Clicking sound unless your bearings are going??? another option??? hell i guess i could sit here and just keep thinking stuff up, but that would require my brains 2 little gears to keep on grinding more than they already are... hehehe
    good luck to ya
    Ck1500
    /forums/images/graemlins/ears.gif
  3. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Well, the last time it made this sound I didn't have a clue what it was. I ended up taking it to the dealer to make sure I got it right. They showed me the fill plug on the front transaxle. The front drive shaft goes into it. It was bone dry. They put 2 quarts into it. I check it on a regualr basis, when I change my oil and check everything else. Always full.
    Changed? Hrm...never changed it. Is there a drain hole for the front diff? /forums/images/graemlins/confused.gif
    Is there something else up there that I need to check the fluid level on? /forums/images/graemlins/1zhelp.gif
  4. Ck1500
    Feb 8, 2001
    198
    Burton, Michigan
    to my knowledge there is no drain hole on bottom of front IFS diff, but they do have a vacuum pump you can buy real cheap from a Autoparts store to suck all the old fluid outta it??? just another option??? or crack the front diff apart and let it run out?
    Ck1500
    Marc
  5. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    I will find one of them things and change it. What other fluids should I look into since I just went over 135,000 last night?
  6. Ck1500
    Feb 8, 2001
    198
    Burton, Michigan
    welp if i was doing it all at once i would make sure my tranny fluid isn't burnt , ummm the transfer case fluid also, ummm might not be a mad time for a power steering fluid change, "just trying to think of what might WHINE on a truck " ummm that should just about do it, and make sure you got some lube in the Zerk fittings on your U-Joints.
    beyond that its pretty much set, unless its a wheel bearing???? but those normally grind b4 they whine hehehe
    hope this helps
    Ck1500
    Marc
  7. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Gonna go through and check all that.
