whinning when i put in in 4x4
Discussion in 'The Garage' started by blazerjake86, Jan 9, 2004.
  1. blazerjake86
    blazerjake86 Registered Member
    Oct 12, 2003
    19
    whenever i put my truck in four wheel drive i hear a whiining sound kinda like i am going to fast kind of whine. i do not know why. what is the prob?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    sounds like a bearing going out. could be pinion bearing or front out put on transfer case. check to see if the pinion has any side to side play in it
  3. wasted wages
    wasted wages 3/4 ton status
    Dec 3, 2003
    9,194
    Dallas Texas
    Any women with ya ???????????????????
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Is this in high or low range? Whining from the transfer case is pretty normal in low range. /forums/images/graemlins/cool.gif
  5. blazerjake86
    Oct 12, 2003
    19
    low it did not even work in 4high
  6. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    whining is normal when ur in low due to the gear reduction or w/e...not sure exactly how it works but it always does that in 4low....and it doesnt work at all in high you say? doesnt go into 4hi? or it plain just dont work?
  7. blazerjake86
    Oct 12, 2003
    19
    it will go in I mean the light is on but it still acts like it is in neutral
  8. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    It might be in neutral... check your linkage
  9. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    yea i second that..not surprised if the linkage is of or needs adjusting..and u have auto or manual hubs? if you have manual im asuming you locked them..and if ya got auto maybe there not workin right?
  10. blazerjake86
    Oct 12, 2003
    19
    funny thing i tried it again today and it works fine. I am so happy that it is working
  11. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    heh...cool! good chance ur shifter linkage might be a little loose or w/e..at least thats what i would think...keep trying it a while and see if it stays ok.. /forums/images/graemlins/thumb.gif
  12. JHG
    JHG 1/2 ton status
    Jul 28, 2002
    129
    Iceland
    My truck does that also, but in 4H. Its been like that for as long as I have had it (from 1996) and I have stopped worry about it. Should I worry?
    The truck has NP208 and D44 front.
