WHINY T-CASE
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KILLERK5, May 30, 2001.
  1. KILLERK5
    KILLERK5 1/2 ton status
    Oct 19, 2000
    108
    Aurora, Colorado
    When I go into 4-low my t-case whines. What would cause this? On a different note, I'm not sure if this is the exact problem, but it sounds like the chain inside is loose, but i cant really tell what or exactly where the noise is comming from. Please help!
  2. 1big78k5
    1big78k5 Registered Member
    Apr 1, 2001
    92
    moosup, ct. usa
    Usualy a whiny noise is caused by a bad bearing. As far as a loose chain goes that is very possible with a NP203, it sound like it might be time for a rebuild!
    '78 K5 SB400, T350, NP203, 35" Swampers
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Is this in your 88? If so, then some whining in low range seems to be normal for those t-cases. My '87 K5 whined in low range, as do my '91 S-Jimmy and my '94 Suburban. It's just the nature of the beast. [​IMG]
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    How loud is the whine? What other sounds lead you to believe the chain is loose? I've always noticed a small amount of whining with the TC engaged........or maybe that's just the two twerps in the back seat that I'm hearing!!!!!!!!!!!!!
    Seriously though, I've owned the truck for 9 years and have always noticed a subtle whine in 4x4. I'd imagine if the chain is stretched or damaged you'd hear some rattling, too.........
    <font color=red>PHOTO ALBUM-</font color=red> <A target="_blank" HREF=http://albums.photopoint.com/j/AlbumList?u=1289798>http://albums.photopoint.com/j/AlbumList?u=1289798</A>.......<font color=blue>TRUCK & HIKING PICS</font color=blue>
  5. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    i love that whinning sound!!! that means its "business time"
    AIRBORNE!!
  6. Oblin Goblin
    Oblin Goblin 1/2 ton status
    Apr 30, 2000
    205
    Davis, CA
    My T-case has always wined in low (but not high) so I hope it isn't a problem. I usually cant hear it below 10-15 mph but above 20 it sounds like a stick shift in reverse.
  7. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    I thought my T-Case whined when I put in in four wheel drive but, I found out that the coupler betweent the CV joint on the front drivshaft was shot. It wallowed out the hole and I had about an inch and a half slop in it. At least I know what has been causing all that noise!
    74 Blazer
    Zepplin
    See my site at: <A target="_blank" HREF=http://www.jeremyb.coloradok5.com>http://www.jeremyb.coloradok5.com</A>
  8. ericsoffroad
    ericsoffroad Registered Member
    May 29, 2001
    27
    wa vancouver
    if your running a 208 t-case it will whiny mine dose and every one i have ever see has made nois in low range
  9. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    How many have you seen ?
