whistling sound coming from the carb
Discussion in 'The Garage' started by adamforsythe, Sep 5, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    I have a whistling sound coming from my primarys on a Edelbrock 600CFM carb. I can only hear it when I take my air cleaner off (NOT A STOCK ARE CLEANER SEE ENGINE PHOTO IN SIG.) I have no hoses running to my air cleaner so I am not cutting off any vaccum from the carb.
    Adam
  2. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    fairly normal..
    My Edelbrock has a whistle too!--so does my Carter AFB on my 400 I had--it does it most after its hot at idle--and co-incidentally it does it loudest when its adjusted perfect!--maybe its whistling a happy tune? :whistle: (like Dixie!) :haha: :rotfl: --if your sure there are no vacuum leaks,I wouldn't worry--I dont hear mine whistling since I ditched the crappy Edelbrock foam "stealth bomber" air cleaner in favor of the stock one..
    Many carbs""whistle" while idling--the venturi and butterflies restict the airflow like you lips when you "pucker up"..makes a whistling noise...I suspect the "hot idle compensater" in many carbs is responsible for whistling too--they are nothing more than a hole in the carb open to manifold vacuum,covered up by a Bi-metal spring steel dewhickey with a rubber seal..they open slightly when its real hot out,and lets a bit more air in to lean the mixture out a bit so it wont be too rich.. :crazy:
  3. HELLBENT DESIGNS
    HELLBENT DESIGNS 1/2 ton status
    Apr 2, 2005
    453
    bozeman mt
    running a square bore carb (holley edelbrock) on a manifold that fits both a spreadbore and squarebore carb can cause a whistle. the squarebore gasket overhangs the inside of the manifold. ever take a broad blade of grass and whistle with it? basicly a reed! same principle with the overhanging gasket. i did a carb-intake swap on a 84 k5 of a buddies. got a loud whistle. ended up pulling the dist. carb, hours later :mad: never quit :mad: he took it to another guy that had run into the problem. he trimmed the gasket down which helped a bit but not fully, i still call his blazer "cricket" edelbrock makes a plate that corrects the problem :D
  4. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Well I don't really care just as long as everyone thinks my carb is fine. I just did not want to be 2 million miles away from home and have it give it.
    Adm
