Whistling sound on acceleration
Discussion in 'Audio' started by afroman006, Mar 12, 2005.
  1. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    My stereo just started making a VERY annoying whistling sound during acceleration today. My setup is and Alpine CDA-9807, crossfire and profile amps and crossfire speakers. The stereo has been working fine for the last year and it jsut started making the sound today. Its always present when the stereo is on and the pitch gets higher when I accelerate. The volume of the noise is constant no matter what volume the stereo is on. Anyone know what it is?
  2. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    I'd go straight to the spot where the amps are grounded to the frame (or sheetmetal) and pull that connection.....clean the metal and connectors and then re-attach everything.
    Sounds like a classic "ground loop"...which is almost always a grounding problem. Especially in your case, since it's "appearing" now...where it didn't used to be there.
    Let us know what you find.
    :cool1:
  3. personaltrainer
    personaltrainer 1/2 ton status
    Nov 4, 2004
    178
    Atlanta GA
    I second that - sounds classic. probley the ground - clean em up.
  4. tayven
    tayven 1/2 ton status
    Jun 16, 2004
    125
    Northwest
    Or...
    Or your power wire and and your Audio cables are touching and getting a weird feed back. I have had that problem on a couple of different cars.
  5. PhoenixZorn
    PhoenixZorn 1/2 ton status
    Mar 17, 2005
    1,734
    West Allis, WI
    Another thing it could be is the fuse you are using... there is a dampenner available from most audio shops that can eliminate or at least reduce the whine you hear from your engine in the speakers. Like the other guys said, the first course of action is to clean up the ground... corrosion is common, and it will cause all sorts of goofy things to happen.
  6. afroman006
    Aug 21, 2002
    2,876
    Well I checked and cleaned the ground. It was dirty so I cleaned it prety well but its still whistling as loud as ever. What else should I check?
  7. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Did you check your other grounds also? Like the engine block to firewall braided wire or the battery to engine block/frame cable. The cab is electrically isolated from the frame so it gets its ground from the firewall connection.
    Also, whenever I mess with any electrical connections I always use dielectric grease on my connections to give it a better connection and help prevent corrosion.
  8. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    I agree....the ground is still the problem....check the remaining grounds (engine block to frame, frame to battery, etc)
    Those "braided" ground straps don't last forever and many people replace them with a conventional round wire. You might try that if cleaning up the ends doesn't seem to be making any difference.
    The dielectric grease is a good idea also....cheap insurance and keeps the air out to prevent oxidation next time. :thumb:
