White/Black Smoke
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Hayduke, Aug 8, 2000.
  1. Hayduke
    Hayduke 1/2 ton status
    May 9, 2000
    271
    NE Columbus, Ohio
    here's what's happening, it seems like i'm burning oil, when i hit the gas from a stop a white cloud puffs out of the pipes, kind of big too. sometimes i seem to "burn" more than other times, if i'm sitting in stop and go traffic it smokes the most. it doesn't smoke much when i'm just sitting, just when i touch the gas. and if i put it to the floor a black cloud puffs out. also on a recent trip to west virginia i noticed thin black smoke coming out of my pipes whenever the truck was straining to keep speed on a really steep long climb....
    BUT when i check my oil VERY little is being lost, maybe under two quarts between oil changes.
    any input? it's a stock 1986 305, just under 100k on it....
    thanks.
    HAYDUKE
    Insured By COLT.
    http://haydukesk5.coloradok5.com
  2. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Sounds like your rings are shot. This would produce black smoke cause of unburned fuel, and white smoke due to oil escaping past the rings and up into the combustion chamber. It's only a matter of time before "Johnny-Law" pulls you over for a fix-it ticket due to excessive smoke. Time to rebuild!
    ken
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    This is what I have always been told and my experiences:
    White Smoke = Water/coolant
    Black Smoke = Fuel
    Blue Smoke = Oil
    You may have a tiny coolant leak into you cylinders somewhere, headgasket?
    Mike [​IMG]
    1982 GMC Jimmy - <font color=green>Emmett</font color=green>
    http://emmett.coloradok5.com
  4. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Maybe your carb needs a tune up. It could be running rich. The fuel/air mixture maybe off a bit. That's a thought.
    Boss
  5. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Good call, Emmett. Does your engine have an aluminum factory intake? If so (or even if not) the intake gaskets may be leaking coolant into the intake tract, which would cause the white smoke. If this is true, then it's only a matter of replacing the intake gaskets. As for the black smoke, maybe, like others say, your carb is out of tune.
    ken
  6. Scoobydoo
    Scoobydoo 1/2 ton status
    Jun 9, 2000
    244
    Phoenix / Peoria ARIZONA. (75thAve/DeerValley)
    Yep, what they said! about the smoke colors is right.(white=water, black=gas, blue=oil)
    Also are you losing coolant?(it doesn't have to be much) does your tailpipe smell sweet like antifreeze?(assuming you do use antifreeze) If so you need a head gasket, which one is your guess?
    The "black" is your air/fuel mixture and it is not uncommon for it to run rich when going up a mountain! think about it you are changing elevation so air is getting thinner and you are heavy on the gas. you may just need an adjustment or a rebuild on your carb.
  7. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Check the underside of your oil-fill cap for sludge that looks like curdled chocolate milk- this indicates coolant in the oil.
  8. Hayduke
    May 9, 2000
    271
    NE Columbus, Ohio
    Ok guys, here's what i've found....
    a small internal coolant loss, wouln't have noticed it if i wasn't keeping an eye on it. changed my oil today and pulled a couple of plugs out to take a look at 'em and they are fine, no oily build up. i also drained the oil into a clear jug and so far there has been no water seperating out of it. i'm watching the "cloud" that puffs out more closely too and it is a nice white color. i'm leaning away from my rings and more toward my intake gasket? anymore input?
    thanks!
    HAYDUKE
    Insured By COLT.
  9. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    Sometimes I see a puff of white smoke when I start my k5 in the morning. Is this bad?
    Brian
    84k5, 4"Skyjacker lift,33x12.5 Goodyear MTR, 15x10 Bajas
  10. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    Hey my rig did that, I got some of this stuff called STP Smoke treatment at advanced autoparts and poured the bottle in the oil thing and boom problem fixed next time i cranked it up.
    Dawson
    88 K5 167k miles
  11. jim82
    jim82 Registered Member
    Jun 27, 2000
    71
    Bay Area
    84 that white smoke on start up, make sure it isn't blue. if its blue its probably just the valve guide seals letting a little oil thru, had this hapen in a couple a cars, new ones are cheap and not too hard to do.
  12. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Mine has some white smoke on startup occasionally and i think its pretty common on 350s.
    90K5
  13. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Usually a little white smoke on start up is normal. Its just a little condensation. What is common on <font color=red> 350's </font color=red> is the little puff of blue on start up. I personally have never seen the intake gasket being the culprit for white smoke, if it was the intake gasket it would run pretty crappy. When it is cold take the rad cap off and start it up, wait for it to settle down and start looking for bubbles, if the head gasket is gone quite often you get exhaust in the coolant and coolant into the cylinder. My friends 4.3 had a blown head gasket and we did a leak down test and almost had a geyser blowing out thru the rad cap. It was also blowing white smoke.
    Just my 2 cents
    Rene 81 Jimmy,350,SM465/NP205,FF14 bolt,HD Dana 44,3.73's,4"susp.,35"Grabber MT's,body in progress
  14. Mr Red
    Mr Red 1/2 ton status
    263
    Washington, DC Metro Area
    Intake or Head gasket. Maybe try checking tourgue on intake bolts (in proper order) and / or replacing intake gasket first & pray it ain't the Head gasket or cracked head.
    Good Luck,
    <font color=red>David, '86 K5</font color=red>
  15. 89Jimmy
    89Jimmy 1/2 ton status
    192
    Northern N.Y. east end of Lake Ontario
    My '85 had some pretty significant white smoke(steam) out the exhaust after warm-up. A packet of bars-leaks brown pills in the radiator cured the symptom till I can open 'er up. Local GM Tech told me bars-leaks was recommended in the GM manual as part of intake work, and also used on alum. head motors. Who am I to argue?
    John
    So Much to do, So LITTLE cash.
