White gear lube???
Discussion in 'The Garage' started by DukeBoy88, May 26, 2004.
  1. DukeBoy88
    DukeBoy88 1/2 ton status
    Oct 16, 2002
    315
    Jonestown Pa
    I just popped the cover off the 14-bolt on my M1008 and the lube was bright white, vanilla milkshake looking. everything inside appears to be ok. 54,000 on the truck. what is this? Fluid up front in D60 appears normal.
  2. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Gear lube + water = gear lube milkshake. Drain it, refill with new lube and check the vent tube.
  3. DukeBoy88
    Oct 16, 2002
    315
    Jonestown Pa
    Thats what I was thinking, but didn't expect it to be so bright. doing a gear change anyhow so it'll get cleaned out and replaced. thanks /forums/images/graemlins/thumb.gif
  4. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Go ahead and replace it again shortly after install. You might be amazed at just how little water it takes to ruin the fluid.
  5. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    You have water in that diff and need to replace it imiedately before it damages anything. Check all your seals. If they can leak gear oil out, then can leak water in. Also check your vent tube is routed up high enough.
  6. DukeBoy88
    Oct 16, 2002
    315
    Jonestown Pa
    Have it completely torn down now, everything getting scrubbed in the parts washer. rinsing the housing with brake cleaner. seals appear ok, no leaks that I know of but I've only had it for 1000 miles. vent tube mounted to bottom of bed. someone may have submarined it before I got it. Installing 3.73's to be my DD, toy-hauler. will change the fluid again soon as well. Thanks for the help. /forums/images/graemlins/waytogo.gif
  7. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    After you have the vent tube mounted run it back down a few inches (like an upsidedown "J") to make water less likely to enter.
  8. kennyw
    Jun 9, 2002
    13,224
    94
    Sounds like your gonna get all the water out and not have to worry about a second oil change.
