White smoke at startup
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tomseviltwin, Jun 18, 2004.
  1. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Is burning oil the only possible cause? Getting more of it as time goes on. Doesn't really smell like oil, and I don't seem to be using any (dipstick)
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Mine does this all the time, but i have over 215k miles on mine, how many miles are on yours? If it goes away after awhile, it's just the tyical valve seals on the heads, they are notorious for this on Chevys.
  3. tomseviltwin
    Dec 23, 2001
    2,065
    Utah
    134,000. Not too worried. It goes away right after the 1st puff.
  4. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    Mine does the same thing....134K also...long as it passes Inspection, it'll wait until I decide to drop in a new crate motor...ain't the least bit concerned about it...I use less than half quart on a 1400 mile road trip (runnin' 75-80)...
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Typical GM problem. The valve stem seals get brittle and let oil leak past. When parked overnight, enough oil leaks past them to leave a good film on the valves. It gets burned off on startup and gives you that nice blue puff. But it isn't much oil, so it will take a very long time to see it on the dipstick. (A very little bit of oil makes quite a bit of smoke!) New seals cost around $15, but they're a pain in the a$$ to change on a TBI engine 'cause some a$$hat "engineer" at GM designed the serpentine style accessory brackets so that they have to be unbolted from the front of the engine before you can remove the valve covers. /forums/images/graemlins/angryfire.gif Once you're inside, you can change all the seals pretty easy. I swapped the seals on one rig and now I just ignore the puff from the others... /forums/images/graemlins/wink.gif
  6. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    some people are anti- Maxlife, but after I switched to Valvoline Maxlife the puffing went away. I run 10w40 in the summer and 10w30 in the winter. Very little puffing these days /forums/images/graemlins/waytogo.gif
  7. 4xcrazy
    Oct 31, 2003
    9,471
    5
    Geez, if i run 10/40 or 10/30, i will be adding oil every other day just to top it off, as it is between my 2500 mile oil changes, i usually will put in 2 qts between changes.
  8. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I tried that stuff...
    I it took a while to work...
    At first I was saying... "It's a miracle!!!"
    "I'm not seeing any smoke!!!"..
    But...I checked the oil level..and found I had to add 4 qts.. /forums/images/graemlins/doah.gif
    I actually burn less oil with regular 1040w...
    Personally I think your better off using 1030-1040w...
    and adding some Lucas.... /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  9. tomseviltwin
    Dec 23, 2001
    2,065
    Utah
    Well, it passed the emissions sniffer /forums/images/graemlins/pimp1.gif Now it's a purple haze till next year /forums/images/graemlins/peace.gif
  10. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    It should pass for many years to come, even with the bad valve stem seals. They typically don't let much oil get past while the engine is running. Most of it leaks down while the rig is parked. /forums/images/graemlins/cool.gif
    My '90 passed the sniffer, but failed the visual for "visible smoke" because at 2,500 RPM the tailpipe looked like an old mosquito fogger! /forums/images/graemlins/eek.gif The rings are shot...
  11. Bruiser
    Bruiser 1/2 ton status
    May 21, 2000
    320
    Caldwell,Idaho
    Uhm white smoke and everyone says oil? Oil is blue smoke, white is water or coolant. It is normal for a vehicle to blow white smoke when it is first started, as long as it goes away. Has to do with condesation in the exhaust system as it cools (may notice some cars drip water out the exhaust)
    Blue smoke - oil
    White smoke - coolant
    black smoke - Rich
  12. 4xcrazy
    Oct 31, 2003
    9,471
    5
    White,,,,blue,,,ya'll are crazy, it all looks the same to me, white, i never understood the "blue smoke" theory, there is no blue in the smoke, if it's water, it's steam coming out, not smoke, steam goes away after a few seconds of the exiting of the tail pipe, smoke lingers around and smokes up the neighborhood.
  13. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Yes, cars will blow out some steam if it is cool outside and the engine is warming up, but the "puff" we're talking about here occurs immediately after startup and only lasts about 1/2 second. There is a very noticeable difference between the two.
  14. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    when the hell is it cold enough for steam in phoenix /forums/images/graemlins/confused.gif /forums/images/graemlins/screwy.gif
  15. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Techically if 100 % COMBUSTION were to occur , the exhaust would be water and extra oxygen . But as it is some vehicles ( watch when you are in rush hour newer vehicles ) drip some water from the tailpipe . /forums/images/graemlins/k5.gif
  16. backcountry
    backcountry 1/2 ton status
    May 27, 2004
    916
    LOL! For sure! /forums/images/graemlins/waytogo.gif
