white smoke coming out of exhaust????
Discussion in 'The Garage' started by Blue Goose, Aug 26, 2005.
  1. Blue Goose
    Blue Goose Registered Member
    Aug 22, 2005
    20
    South Dakota
    I have white exhaust coming out of my tailpipes. It's a brand new rebuilt motor, and I checked my oil, and it was fine. I checked my coolant, and it was a little low, so it must be coolant right?
    I noticed a couple weeks ago it had white smoke coming out of the exhaust, I got kinda nervous about it, then it quit. Well, today I am out driving around and I see it come out, it was mostly out of the drivers side exhaust I believe? Anyways, it smoked everyonce in a while, and then it quit later on when I had someone take a look at it with me, so get a second opinion on what color the smoke was (my girlfriend said blue) but it was definetely white.
    I also stuck some paper in my exhaust tips, and it was kinda....wet in there? and it was black, black and wet..........hmm? any ideas?
    again it burns no oil so anyone have any suggestions? and if it was antifreeze/water, did it hurt my motor any?
    anyway I can diagnose this problem???
  2. Blue Goose
    Aug 22, 2005
    20
    South Dakota
    ttt
    could I have a bad head gasket?
    I have put about 6,000 miles on this motor, so nothing should be hurt right?
  3. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    might be an intake gasket... as long as its not overheating the head gaskets should be fine.
    If you want to know for sure do a leakdown test on your cooling system... if there is any leaks in the gaskets they will show up. Autozone will rent u one for 75 bucks IIRC then they give you the money back when u bring it back.
    Don't worry about black and wet... every single exhaust pipe on a combustion motor will look like that. Just carbon from exhaust and condensation inside the muffler when it sits.
    Is it steam or smoke?
  4. Blue Goose
    Aug 22, 2005
    20
    South Dakota
  5. diesel4me
    Jul 24, 2003
    17,577
    945
    Massachussetts
    Other possibilities...
    If your tranny modulator ruptures its diaphram,dextron gets sucked into the intake and burned--and it makes more of a white smoke than motor oil does..it eventually will lower the fluid level in the tranny,and you'll notice slippage..it makes it shift poorly in most cases too,or wont upshift into 3rd.
    A master cylinder can leak brake fluid into the booster and it will get burned in the motor too,causing white smoke..added any brake fluid to the rear chamber of the master lately??..
    Anti-freeze is the most likely culprit for white smoke..a pressure tester will help make leaks easier to find..many chevy's have tiny cracks in the heads that only weep antifreeze ocaisionally,sometimes "Bars Leaks" or other radiator sealer works to plug them ..if its a head or intake gasket,and enough anti-freeze gets in the crankcase,your bearings wont last for very long.. :doah: :crazy:
  6. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    If it is a diesel as you name suggests then water in the fuel and or air in the injector lines can cause white smoke in the exhaust
    EDIT, sorry read name of replier
  7. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,089
    489
    Grand Rapids area
    What does the exhaust smell like?
  8. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    burned antifreeze stinks real bad, nothin else like it.
