White smoke in exhaust...
Discussion in 'The Garage' started by dremu, Oct 2, 2005.
  1. dremu
    Feb 27, 2000
    15,968
    461
    East of San Francisco
    usually indicates water/antifreeze in exhaust, right?
    I note there's also some kind of ATF leak, maybe from the tranny tailshaft, so what I saw may have been ATF burning off the muffler :crazy:
    I did a compression check, and all eight are 130-140, well within the 120 min 150 max specified by messr. Chilton.
    Should I tear the heads off anyway (blecht), or based on the compression check can I assume I'm okay?
    I did check the water level in the radiator, which was low ... so I refilled it. Is the water level in the radiator supposed to stay at whatever level I fill it to, or will it equalize with the overflow bottle or something?
    Aarrgh.
    -- A
  2. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    i'm betting its tranny fluid on the exhaust..
    if it held compression, your probably ok in that department... a pressure test of the cooling system will tell ya for sure if your losing coolant... if you can't beg/borrow/rent one, at least check for bubbles when its filled and running...
  3. dremu
    Feb 27, 2000
    15,968
    461
    Look for bubbles in the overflow tank, presumably ... or in the radiator?
    -- A
  4. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    radiator... its a sign that combustion from a cylinder is getting in the cooling system...
    cooling system pressure tester is a great tool.. i don't know if Autozone rents em, maybe..
    leakdown tester is handy too.. it'll tell you exactly where a cylinder is having an issue.. valve, rings, head gasket, etc..
  5. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    You can also check your upper radiator hose when its running and warmed up, if its hard like it has pressure then it could be your head gasket. But from the compression i would think your ok. And i definately wouldnt tear into the heads if you dont have too.
