WhiteKnight, or anyone who wants to venture a guess, what is this?
Discussion in 'The Garage' started by sled_dog, Jan 22, 2004.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Ok in the video of the Nissan or Yota whatever, tube creation that seems to like to break things, what is the coilover shock over the rear axle between the coilovers for? Its right at the beginning of this movie if any of you care to venture a guess.
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    it looks like some sort of axle flexing suspention. looks like they put alot of work into to it and it did't work /forums/images/graemlins/rolleyes.gif if you look closely the axle tube it looks spliced to allow for it to flex and the spring controls it /forums/images/graemlins/deal.gif
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I think it did work it was his front axle he kept snappin' in 2. /forums/images/graemlins/thumb.gif
  4. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Looks as though his shocks are mounted to a hinge point that is inturn controlled by the horizontally mounted coil over. I think with this setup you could have more rates to your susupension than a single coil over would allow. Suppose your vertical coilovers are soft and the horizontal is set stiff. When your soft coil over bottoms out then it would hinge and pull against the firmer horizontal. It would also pull on the opposite vertical shock. This thing would probably act very squirly.
  5. white_knight
    white_knight 1/2 ton status
    Feb 23, 2001
    1,171
    Calgary, Alberta,Canada
    It is a sort of hinge set up that will clip open. It gives more flex. It works well. We were thinking of doing it at one time. Sort of a shackle flip
  6. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    huh? /forums/images/graemlins/confused.gif
  7. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    So does it have some kind of bump stop to keep the pivots from stretching the center coilover? Would it work similarly with a bar and pivot points? It is definately and interesting idea.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It looks cool, but I can't see clearly enough to tell how it works.
  9. white_knight
    Feb 23, 2001
    1,171
    My mistake- the center coil over is sort of a stabalizer sway bar I think. I thought you were talking about the extenders on the coil overs.
