who all is running 35's and did you have to get the ol sawzall out
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by LKJR, Nov 1, 2002.
  1. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    who all is running 35\'s and did you have to get the ol sawzall out
    well I'm running 31's right now on a stock truck, did the RTI ramp last week and I had the rear stuffed most all the way and the wheel well was pretty full, as in no more than 2" more would have fit, looked like anything bigger I"d have to start cutting, seems like some of you are running 4 sus / 2 body or 6" suspension and haven't cut anything, those of you who have, how bad are yours rubbing
  2. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Re: who all is running 35\'s and did you have to get the ol sawzall out
    I ran a 4" kit from Rancho, which was front springs, rear blocks. I also have 35"BFGs and had no major rubbing I only cut the front edge of the rear fender a small amount and at full steering lock the front would rub at compression. But not enough to cut the front fenders. /forums/images/graemlins/grin.gif Oh and the tires are mounted on 10" wide wheels
  3. Larry_in_Tx
    Larry_in_Tx 1/2 ton status
    Oct 24, 2002
    404
    Houston Tx.
    I've got em on 10" rims on 6" of susp. lift and have no bad problems. The only place that rubs at on the front fender right behind the bumper at full compression but it's not bad enough for me to do any cutting.
  4. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    don't be a puss. /forums/images/graemlins/rolleyes.gif
  5. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    puss, I"m not too woried about minor trimming if I need to.. btw isn't it time for some updated stuff on that trailer beast of yours
  6. laketex
    6,220
    North Texas
    I've got the dash done, new rockers, full convert, new frontend...just what were you wanting pics of????
    LOL /forums/images/graemlins/thumb.gif
  7. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    My 35's bit the rear wheel well with a 4" lift .. went to a 6"/8" lift and no problems on 15X8 or 15x10s
  8. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Mine hit is two spots. The rear of the front wheel well and the front of the rear wheel well. I have 35x12.50-15 SSRs on 15x10wheels. Running 3"bodylift 4" Rancho up front and 5 1/2"Superlift springs in the rear. I have already done some trimming and they still rub so I have a bit more to trim. I do some peerty twisty stuff so they only hit on the super flexy stuff... /forums/images/graemlins/thumb.gif
  9. Scorpion
    Scorpion Registered Member
    Jun 5, 2002
    60
    Denver, Colorado
    6" softride and 35" MT. No body lift, absolutly no rubbing on full flex...but it's dang close.
  10. Ryan B.
    Jul 18, 2001
    5,693
    CA
    I'm running 8" rear/ 6" front skyjacker softride springs, and 35x12.50x15 BFG muds on 15x10 rims. They don't rub in the rear at all, the drivers side front will rub the rear part of the fenderwell when really flexed.
  11. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    i have 4 inch lift springs and run 35's.i have no rubbing and you can se my flex by clicking the link below.
  12. 1970Jimmy
    1970Jimmy Registered Member
    Apr 27, 2002
    75
    Cookeville, TN
    I have 35 x 12.50s on 10" wheels with no lift (I have the 1" lift solid 14BFF perches from a member here)> BUT...I wasn't bashful when it came to cutting any metal. I used a sawzall and die grinder/cut-off wheel to "trim" the Jimmy. I rub just a little in the front on the driver's side, but that is because my inner fender hangs down just a little. Don't be afraid to cut...it's what all the "cool" kids are doing!!
  13. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    you got any pics?
