Who all is running Dual Batties and who thinks it was worth the expense
Discussion in 'The Garage' started by Mudbug1979, Sep 6, 2004.
  1. Mudbug1979
    Mudbug1979 1/2 ton status
    Aug 4, 2002
    439
    Monroe,North Carolina
    I've been considering running duals for awhile now, but I was wondering if there was anyone who wishes they hadn't spent the money on the upgrade. Sounds silly to ask I know but stranger things have happened. With two differnt age and size batteries do I need to run an isolater. I know this has been covered for a while now, But I haven't found out what I needed to know. Thanks
  2. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    i havent yet, but am in the mist of finding time to make and install the shelf.
    i am going to use a ford selinod to isolat them. cheap. have it hooked up so when you trun the key to on it conects and when its off it isolats. 10 bucks vs like 75 for an isolator, and you dont have to do it manualy with a boat switch /forums/images/graemlins/waytogo.gif
  3. Mudbug1979
    Aug 4, 2002
    439
    Anyone got any wiring diagrams for doing it without the isolater?
  4. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    if you use a winch, i'd suggest you get 2, no matter what.
    if not, the more cranking the better!
  5. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    no /forums/images/graemlins/doah.gif what i am going to do is find the wire that from the ignition, from the on position, (different wire from the acsessory wire that turns the radio on) and run it to the 's' termanal on the selenoud (sp) this way when ever the truck is on you have dule batt starting power, and it will charge the batt.
  6. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    i used the heavy duty kit from painless, i like it alot very well made, i just need to find a batt. tray for the left side of my 89, the way the one from painless works is the main batt dose everything, and the second one is just for starting the truck if the main one goes dead /forums/images/graemlins/peace.gif
  7. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    Our monument setting truck is set up this way. The aux battery runs the hydraulics for the crane and liftgate. We have been using the same aux solenoid for over 20 years, no joke.
  8. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    i was looking at a isolator at an RV place, it was 90 bucks, huge, and had heat fins you had to watch how much amps you run draw blah blah blah, so i had to get a huge one.
    then i thought of the selenoud, continus rateing, cheap and atomatic. (don't want to have to switch it, worryed about leaving it on /forums/images/graemlins/crazy.gif)
    and you can get them anywhere. /forums/images/graemlins/peace.gif
  9. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    I like darkshadow's idea for a cheap isolator by using the Ford solenoid. I have heard that the Ford solenoids will melt if used for a continuous duty application, maybe getting something a little more heavy duty. If you have 2 identical batteries I would suggest hooking them directly together. If you have 2 different batteries it would be a good idea to isolate one of them, the Ford solenoid would work good for this. I plan on using 1 start battery and 3 auxilary batteries in my truck (all from a semi). I plan on having some big current draw though. Whether or not it is worth running dual batteries depends on your electrical requirements.
  10. Xtreme Off-Road
    Xtreme Off-Road Registered Member
    Apr 27, 2003
    48
    Ontario, Canada
    That is right it will melt. Use a constant duty solenoid. I use snow plow solenoids and have good success with them.
  11. Mudbug1979
    Aug 4, 2002
    439
    Anyone have any part numbers or tell me where to get one because I do want to add this to my vehicle, But if I didn't need the Isolater then I wasn't going to spend the money on it. If I do then it's no problem.
  12. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    yup, dito on the melting...they stink like hell too when they do!
    I tried to use it for my elect fan set up... /forums/images/graemlins/doah.gif
  13. gravdigr
    Apr 15, 2003
    1,129
    Tyrone, PA
    One thing, the solenoid is only to connect the charging circuit to the battery. You should connect any accessories directly to the battery (winch, plow, liftgate, whatever). The solenoid you want should have a metal case.
  14. Storm Trooper
    Nov 24, 2000
    4,640
    I ran a isolator and did all the fancy stuff only to have problems charging my secondary battery. I dumped it all and just hooked them both up together and have never had a problem again. I run a warn 9.5ti winch, a 400w sterio, 5 overhead off-road lights and two rock crawling lights.
    I also have a powermaster alt. that puts out 140 Amp.s and two optima yellow tops.
    The only thing that was nice with the isolator was that I could jump start myself but now I have never needed too.
  15. Mudbug1979
    Aug 4, 2002
    439
    Yeah, but I have two different batterys with different cranking amps. Should I just get rid of the second battery and buy a new one. The one that's in the truck now is about a year old and I have the Powemaster 140Amp alt. also. I would love to go to Optimas but the approval committee won't alow that right now.
  16. gravdigr
    Apr 15, 2003
    1,129
    Tyrone, PA
    The problem with connecting the 2 batteries together is you lose your redundancy. If 1 battery goes it will take the other with it. If something in your wiring is draining your battery it will drain both batteries. You also need to use identical batteries when you hook them up like that. Not saying it's wrong, you just lose some utility.
  17. semper-k-five
    semper-k-five 1/2 ton status
    Aug 16, 2004
    326
    Tulsa, OK
    I have a dual set up in mine w/ a ford solenoid and an isolator...it's been on there for years and no probs yet...of course there always the threat of burning up the solenoid, but i haven't had any problems...and definetly run an isolator switch...honestly, i don't think you can run it any other way...i've left mine on by accident once or twice and i do get excessive voltage since i don't have a ton of excessories...and the ability to self jump start is a plus when you're automatic!!! as far as wiring diagrams, i believe there is a post out there that has a pretty good draw up of a digram using a ford solenoid...try doing a search for "wiring diagrams"
  18. semper-k-five
    Aug 16, 2004
    326
    Tulsa, OK
    forget the search!! forgot everything was lost after the server problem...
  19. Mudbug1979
    Aug 4, 2002
    439
    Ok, so where is the best "Cheapest" place to get a isolater and will that have all the stuff to do the install (ie: switch, connectors) I know I will have to get wires and all that good stuff. Some of you have mentioned using a solenoid. Why do I need one if I'm using a isolator? I'm sorry for all the questions but I'm not that great at wiring. Thanks again.
  20. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/thumb.gif
