who can explain a torque converter to me?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zach78k5, Aug 7, 2004.
  1. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    It may sound stupid, but this is the one part of my truck I dont understand at all. What does the torque converter do? Can i replace mine with one that will give me more low end torque. How does the torque converter work? thanks for your help.
  2. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    I dont quite understand, but its like slipping your clutch on a manual tranny.
  3. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    Look at it like as a variable pressure hydraulic pump, low engine RPM=low hydraulic pressure, higher RPM = higher hydraulic pressure, and thats about all there is to it, the whole concept behind an automatic trans is hydraulic pressure, and rotating torque being transfered. if you saw a diagram of hydraulic pressure application and torque transfer, it would all come together for you, auto transmissions are not rocket science /forums/images/graemlins/thinking.gif /forums/images/graemlins/waytogo.gif
  4. zach78k5
    May 14, 2000
    406
    So if I had a torque converter that created a lower pressure would my tranny tend to downshift easier? What is stall point?
  5. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    what does it mean when a torque converter stalls, or whatever?
  6. unclematty
    Jan 24, 2003
    3,164
    SLC UT
    No, downshifting is almost totally controlled by what pressure the shift points are set at, it can be altered by installing a shift kit. A stall point is where the nearly full hydraulic power, is basically unleashed into the transmission, all at once IE: 1500 rpm stall speed= no hydraulic pressure is applied until approximatly 1500 rpm, the stall speed is an estimation,probably within 10%, hopefully that helps /forums/images/graemlins/thinking.gif /forums/images/graemlins/waytogo.gif
  7. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    okay I understand. Thanks /forums/images/graemlins/peace.gif
  8. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    What is the stock converter stall speed in a TH350?
  9. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
  10. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    thats a good article speakchucker! /forums/images/graemlins/peace.gif
  11. spearchucker
    Nov 17, 2003
    1,556
    Bay area, CA
    You'll be on that site for days reading stuff. /forums/images/graemlins/grin.gif
  12. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    A torque converter can be a huge help or a huge pain offroad. You should have a torque converter to match the kind of wheeling you do and match the setup of your truck.
    If you run mud then a higher stall converter isn't a bad idea. If you run rocks like me a lower stall is the ticket. This depends on the setup of your truck though also. If your truck is a rock truck but you don't have a low enough gear ratio then a low stall converter can be a bad thing. You will never get your motor to a high enough RPM to spin the tires if you need to.
    I run a 1200 RPM stall in my truck. It gives me driveablility on the street and it gives me good offroad performance with my trucks setup.
    Harley
  13. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    haha! I bookmarked that site so I could read up on a bunch of stuff! I'll be a walking dictionary when Im done /forums/images/graemlins/cool.gif
  14. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    AFAIK torque converters simply throw fluid with oen set of blades or whatever and throw them through a second set of bladfes or whatever
    slushbox tranny input shaft is not mechanically atteched to the output shaft, they are connected hydraulically
    that fluid is used big time, thats why its so important ot keep it change,d it jsut plain wears out breaks down when it gets so hot or old
