Who can tell me why my gas mileage sucks????6 MPG
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zach78k5, Jun 21, 2004.
  1. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    I filled up today and did the math and i got in the neighborhood of 6 mpg on my last tank. I dont drive what i would consider hard.
    Here is my setup.
    305, 32 in. tires, 3.73 gears, headers, 3 in. single exhast, k&n filter, stock carb, 700R4 tranny. The tranny tends to upshift a little too soon in my opinion and also does not like to downshift when it probably should, without really stomping the pedal. I do a lot of city driving. Could my stock carb be the problem? could the weak 305 be struggling and giving my terrible gas mileage? is the exhaust too big for my engine?
  2. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    Your setup doesn't look like anything that would cause that bad of mileage. I'd run another tank and check it again. Check your timing while you are at it. How does it run?
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    First thing to do is to verify that the odometer is correct. With the taller tires it will show that you've travelled less distance than you really have. So the math makes the MPG look worse than it really is. /forums/images/graemlins/cool.gif
  4. dyeager535
    26,980
    Along with tranny or axles, if they have been swapped or rebuilt.
    I got 18MPG on the freeway with my 305/700/208/3.08/32" combo, got the same with the 350/465/205/3.42/33" as well. (as a comparison to show that CID and gears aren't all that matter)
  5. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Size 12 shoe?? /forums/images/graemlins/dunno.gif
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/whistling.gif
  6. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I'd say your exhaust is too big unless you have a hop-upped 305...hmmm, that sounded wierd using those two words in the same sentence. /forums/images/graemlins/grin.gif
  7. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Why is a 3" single exhaust too big for a 305?
    Seems about right to me. 3" single exhaust definatly wont hurt gas milage.
    Maby time for a major tune up or a new/rebuilt carb?
  8. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    When was the last time you did a tune up? Plugs, wires, filter. Check to see if you have any burnt spark plug wires. Yes, I would say the exhaust shouldn't effect it for having single. Dual maybe a differant story. Is your carb leaking or fuel pump? Try starting it up and looking for leaks and spray carb cleaner around carb while runnin and see if the idle changes.
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I agree , tune it up first, change ALL the filters. Don't forget to replace all the old vacuum hoses. You should be getting great mileage, well great for a 2 ton brick anyway /forums/images/graemlins/k5.gif
    I get great mileage with simillar setup , except I have 33's and 3.08's and smaller exhaust , don't even use OD unless I am doing 60-65 on freeway. Usually see highway numbers like Dorian does, and in town I can go 4 or 5 days to and from work ( 45 min drive one way in rush hour ) on a near full tank /forums/images/graemlins/k5.gif
  10. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    With the 3" on a stock motor, he is losing low end power and that's what he needs if he's doing a lot of city driving. Granted going to 2.5 exhaust won't alleviate all the problems but IMO it should be done... /forums/images/graemlins/grin.gif
  11. MarcS
    MarcS 1/2 ton status
    Oct 4, 2002
    515
    NJ
    Adjust the TV (kickdown) cable. I did it on mine and it's like a totally different truck. /forums/images/graemlins/cool.gif
  12. crazy427
    crazy427 1/2 ton status
    Mar 10, 2003
    979
    Edison , NJ
    Yeah , i would definatly adjust that throttle pressure cable. you can damage your trans if it isnt running enough pressure . moving it away from the linkage will give you firmer and later shifts and make the transmission downshift properly for passing gear.but i dont thnk that would effect your gas milage . i think that the speedo / axle ratio / tire size combo is throwing off your #s /forums/images/graemlins/thumb.gif /forums/images/graemlins/usaflag.gif good luck.
  13. zach78k5
    May 14, 2000
    406
    I just changed plugs, wires, and had the thing tuned up. It actually runs really well. I will check the carb thing. I was reading that a bad fuel pump can actually pump too much fuel and mileage can suffer. Anyone else heard of this?
  14. Polaris
    Polaris 1/2 ton status
    May 30, 2002
    1,182
    Rhinelander, Wisconsin
    My mileage was really bad when I had a brake caliper hanging up. It wasn't anything I could really feel pulling too bad, just a little, but it was enough to give me horrible mileage.
  15. 4xcrazy
    Oct 31, 2003
    9,472
    5
    Yeah, i have really horrible fuel mileage as well, trying to push a 3 ton brick down the road and through the wind really sucks the gas down,,,,, /forums/images/graemlins/screwy.gif
  16. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    make sure yer not leaking fuel either...simple problem that is easily overlooked
