Who carries a raised Dana60 Steering block & how much is the ORD Crossover
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BorregoK5, May 15, 2002.
  1. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Who carries a raised Dana60 Steering block & how much is the ORD Crossover kit? I might block it temporarily untill I can go crossover depending on availability and price of both.
  2. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    2wd box...junkyard
    Pitman arm....$70
    steering arm...$185
    Draglink...$95
    Draglink ends...$130
    Being able to turn while flexed up...priceless/forums/images/icons/cool.gif
  3. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    Mike, you should also check with Parts Mike, I heard he has the crossover system for pretty cheap! And Rockstomper also has pretty good prices on this stuff too! I heard that the raised block is only made by Warn and is quite spendy! You could try to get a machine shop to make you one I guess if you know what dimensions you need...
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    National sels the blocks as well
  5. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    cheapest i found was National----$75 i belive but you should definately do it right the 1st time and go crossover
