Who had the manual hydro tube bender?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Bubba Ray Boudreaux, Sep 22, 2002.
  1. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Got some questions for you. Thanks.....
  2. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    so which one is it? manual or hydro?
  3. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    It was using a engine hoist ram from Harbor Freight. I got the same ram, and using what the guy told me, I finally tried it out today and the ram wouldn't go. The problem is the ram is meant to work vertically, but the guy told me to bleed the ram and fill it as much as possible with hydro oil and it would go. Mine's not working horizontally and I was going to turn the bender so the ram would be vertical, but the way the bender is mounted, I would have to redrill a couple of holes and re-angle the bender. I am hoping to get some tech help on this ram, cause throwing $100 down on a Porta Power right now isn't an option. So far, I have found a ram on EBay that is about the same thing, the seller said it would work horizontally.
  4. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    The bender from William Lo Buck works horizontally. Maybe you can get a new ram/jack from them
  5. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    The jack setup on their's is vertical.
  6. laketex
    6,220
    North Texas
    ZZ4x4 on here uses a horizontal ram...drop him a line.
  7. Butch
    Apr 26, 2000
    1,338
    Austin, TX
    My neighbor uses his with it laying down. Maybe he is just lucky and it happens to work that way.
  8. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    Howdy folks. Bubba, yup, I have the Harbor Freight ram and it is working fine on it's side... but do this:
    -Hold the ram vertically and extend the ram all the way.
    -Lay the ram down with the rubber stopper on the top side.
    -Pull off the little rubber stopper on the side of the ram and fill it up with hydraulic fluid until it over flows.
    -Replace the stopper.
    -Mount the ram with the little open/close valve on the top side with the pump lever pointing up and it should work now.
    I have not had any problems with fluid leaking out being this full, even when I return the ram to its upright position.
    Good luck.
    JT
    Added a couple pics of bender http://jt-k5.rockcrawler.com/bender.html
  9. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Thanks. I'll give it one more go around this weekend and see if I can't get this thing going. I'm ready to bend some tubing.
  10. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    All righty. I redid the fluid fill 'em idea and slapped a piece of 1.25" DOM into the 1.75" (just had to test) and the darn thing is working now. Only problem is apparently my mounting base is not good enough. I have the bender mounted on 3/16", and then went through a piece of 1.5" .120 wall square tubing. The bender was moving, so how thick do you recommend the mounting base be? I found a chunk of .25" steel, weld that onto the table?
  11. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Bubba,
    post a pic of your set up, i would really like to see how it is going!
    TIA! /forums/images/icons/cool.gif
  12. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Yeah, let's see pics. Are you using a tube or pipe bender???
  13. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
  14. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Don't have digital camera and don't know if the roll of film that's getting ready to go in has any pics, but since I'll be clicking next Saturday at the Off Road Expo, I'll make there's some pics of it.
    Even though the die is 1.75", seemed like I wasn't having too much problem testing it on the 1.25" DOM I have, so I may end up doing some front shock hoops here real soon. /forums/images/icons/grin.gif
  15. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    Ok if the regular hand pumped jack works on it's side, how bout this air over hydraulic one?? Anyone try it yet?
    http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=43227
    I wonder if the air cylider can be moved so it would work on it's side. For $90 that would be a hell of a nice deal since the Pro Tools/JD2 air/hydraulic setup is like $1000. As soon as I get some extra cash laying around I'm gonna get this and try it, sure would beat the Hi-lift setup I have now! /forums/images/icons/wink.gif
  16. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    what did the JD3 cost you?
  17. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    $600. I got a degree wheel with it, from reading, don't think it's needed. Didn't have a chance to see if I needed it yesterday. I bent the mounting bolts that came with the bender /forums/images/icons/grin.gif. So looks like I've got some welding to do to the table to stabilize everything.
  18. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Don't know. Probably be worth the try. Is there a mounting hole on the ram itself?
  19. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    wanna bend me up some rear shock mounts??? /forums/images/icons/grin.gif
  20. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Well, if you're not in a rush. Since I'm not getting home til dark from work, it'll probably be a couple more weeks before I get it hooked back up. And I still have to learn myself how to use it.
    What size tubing are you planning on using? /forums/images/icons/grin.gif
