Who has 4 wheel Disc Brakes?
Discussion in 'The Garage' started by 72THING, Aug 23, 2002.
  1. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    Who has 4 wheel discs and what modifications have you done to your brake system? Such as different MC, prop. valve, booster, etc. What were the reasons for these modifications? I've heard all kinds of things you're supposed to do when running 4 wheel discs and I want to know what everybody is actually running and how good it works. Thanks for your time.
    Will
  2. Scooter
    Scooter 1/2 ton status
    Nov 18, 2000
    551
    Grandview, Mo.
    Running the stock MC, booster, and prop valve on mine .. its a little spongy right now .. i think it needs to be bled some more .. but it will stop you in a hurry if needed.
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    I am running 4 wheel disc and have not changed anything other than adding the rear disc. My blazer will stop on a dime and give you eleven cents change.
  4. UNCLE CRACKER
    UNCLE CRACKER 1/2 ton status
    Dec 29, 2001
    937
    PORTLAND OR
    I run 4wheel disc brakes and havent changed a thing and they work great
  5. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I'm also running the stock 1/2 ton master....It's never stopped better!! /forums/images/icons/smile.gif I'm running a D60 & 14bff w/D44 Calipers!!
  6. 84K5BD
    84K5BD 1/2 ton status
    May 19, 2001
    302
    arlington, mass
    i'm running 1 ton mc, hydroboost with stock prop. valve, stops excellent. got sick of removing drums
    to clean mud from shoes, now just spray with hose and its done /forums/images/icons/grin.gif
    84 k5 ,pontiac 455,10' lift ,d60/14ff 40"boggers
  7. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    I'm with 79flatbed... just added the rear discs with D44 calipers, and went on my merry way. I did gravity bleed the system like a mad man though... thing I must have ran about 4 quarts of fluid thru it! :O /forums/images/icons/grin.gif
    The only complaint I have is that the rears lock just a little before the fronts under heavy braking. Other than that, my brakes will stop my 6100lb truck on a dime... just like everyone else said! (Not to mention the dual-piston Ferd calipers I have on the D60! /forums/images/icons/wink.gif)
    -Dan
  8. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I'm running the stock half ton MC but with hydraboost behind it and 4 wheel disks on 1 ton gear. Stops great with no issues even with the 38's.
  9. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,131
    27
    El Paso, TEXAS
    Have 4 disc--dana 44 calipers and rotors on rear--other than that changed noting and stops better than any new car ive ever driven
  10. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I converted my front 10-bolt to 8-lug which is b asically 3/4 ton front brakes with 1/2 ton caliper and I put D44 rotors and calipers on the 14bff in the rear...Have the stock MC, prop valve, and everything as it is when I started the swap...The pedal feels a little soft and spongy, but it the rig stops WAY better with far less pedal effort......
    Chris
  11. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    how do you convert to rear disks and how much is it???
  12. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
