Who has a chart for helicoil drill/tap sizes?
Discussion in 'The Garage' started by BigBurban350, Apr 17, 2005.
  1. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    My trucks drivetrain decided that the 4 bolts between the tranny and t-case should strip themselves out (especially when your a few miles down a nasty trail). I don't have the $45 dollars to spend on a helicoil kit that has the proper sized tap included.
    I have searched google for a while and cannot find the charts for helicoils :(
    Helicoil size: M10x1.50
    Drill size: ?
    Tap size: ?
    Another question, if I can't find a helicoil install tool to borrow, could I use a screw driver or make one out of a wooden dowel?
    Thank You
  2. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    with a helicoil, you need their special tap. you won't be able to find the correct size tap with the thread pitch you need.
    fastenal sells a thread repair sleve that use use a standard tap and drill on and you can buy them individually. i think they are like $5 each maybe even less than that.
  4. BIG STEVE
    BIG STEVE Registered Member
    Jul 23, 2002
    66
    thornton colorado
    The tap for heli coil is for heli coil its not a comon size.
  5. BIG STEVE
    Jul 23, 2002
    66
    thornton colorado
    Big 83 beat me to it
  6. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I have tapped and helicoiled those exact four holes on mine as well. i got my kit at Napa. I think it was around $25 for the tap the helicoils and the installer tool. I also had to buy an odd sized drill bit like somethin 32's but I dont remember it being $45. i couldn't find them on Napa's site but found this for $22
    http://www.midwayauto.us/detailedproductdescription.asp?239.
  7. BigBurban350
    Jun 9, 2002
    711
    Michigan
  8. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Hey what size do you need? I have 5 3/8-16 Helicoils the tap and the insertion tool. All you need is a 25/64" drill bit I believe. I could send ya the stuff if ya send me back the tap and insertion tool. Let me know I don't need them right now and if it will help ya out then cool :waytogo:
    BTW this is the same stuff I used for the back of my TH350.
  9. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i have the same kit, but i think i only have 1 helicoil left. it would be cheaper to ship it, or you can pick it up. i think a refill pack of 10 is like $10 bucks or something like that.
    i used 3/8 coarse thread helicoil for the same holes on my 700r4s. the kit is cheaper and i can use it on more things.
    i know carquest has them for $27, you need the drill though.
