who has actually put a poncho motor in a chevy truck?
Discussion in 'The Garage' started by COCHEV, Jul 20, 2002.
  1. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    my buddy just bought a catalina with a farly fresh 400 in it and needs a little swap info. he is putting it in a 78 short wide with a th350. aside from the obviouse BOP plate and fabbed motor mounts, what else is he up against? also what is a stock ponco 400 rated at? thanks!
  2. 84K5BD
    84K5BD 1/2 ton status
    May 19, 2001
    302
    arlington, mass
    i have , but i swapped in a 455, it wasn't that hard to do. as for power it depends if its built or stock
    if its stock and you know the year you can look up specs in an old motors manual.
  3. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    I've got a TH400 BOP tranny in the garage! Interested? Other than that, I don't expect that it should be a difficult install.... /forums/images/icons/wink.gif
    -Dan
  4. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Below the right side head (passenger side), you should see a stamped two digit letter code on the flat portion of the block. This will have the "Engine Code". Have him get me the engine code and I will tell you what the factory specs are. Also, give me the head code on the center two exhaust ports.
    Pontiacs make loads of torque!
  5. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    If he wants a BOP TH400 I have a friend in Central Oregon with an extra one... Swap out the output shaft for the 4x4 version and it should bolt up to the T-case.
