Who has actually swapped spring hangers on rear axle for a shackle flip????
Discussion in 'The Garage' started by 01maroonz71, Apr 8, 2007.
  1. 01maroonz71
    01maroonz71 1/2 ton status
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    who has actually done this...i've been searching on it for about the last 45 minutes to an hour....and can only find a couple of posts about this. who has taken the front spring hangers on the rear axle and threw some at the rear to flip the shackle??? i do believe it will bolt right up and am trying to build this truck on as much of a budget as i possibly can. what can anybody tell me about this swap??? anybody heard anything????
    thanks guys and gals!!!!
    ~Dave
  2. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    you mean something like this:
  3. 01maroonz71
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    exactly....how much lift did that yield, and how difficult was it. i can pick up a set for next to nothing down here.
  4. muddermilitia
    Nov 10, 2005
    5,742
    76
    NE Illinois
    thats not my truck its owned by 85mudblazin send him a pm
  5. 01maroonz71
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    awesome man...thanks!
  6. littlejimmythatcould
    littlejimmythatcould 1/2 ton status
    Feb 6, 2006
    797
    Clovis, NM
    Me and my buddy did one on his bronco. It was pretty difficult at times. It's not a nice and neat kit like ORD or DIY. THe hardest part was trying to decide when we had them even and level with a good shackle angle before we started drilling holes in the frame. When you drill a hole, put a bolt in it. Every hole you drill put a bolt in it. This keeps all of your holes aligned. And some good big C clamps or C clamp vise grips will be your friend. Also have to drop the gas tank. I think when it was all said and done, He got about 2 1/2 inches out of it. But we were pretty conservative on how far we let it come down. If you wanted to, you could probably get about 3 to 4 with some bracing in the form of an L angle (like they are when you pull them off of some trucks). It took a whole day with dissassembly, fabrication, and reassembly. Just my .02 from my little bit of experience. If someone wants to chime in and fill in any gaps I may have missed.
  7. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    I did it. I used hangers of an 84 K30 and had to drill a few holes to get the correct shackle angle. I mounted them so that the shackle bolt hole was at the same height as the factory mount. I have 57's on mine so I had to drill holes. In the factory location you might luck out with some of the holes lining up.
  8. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    about everyone I run with has used front hangers on the rear. Either drill holes or weld on. Not too hard at all if oyu have the appropriate tools.
