who has built a 383
Discussion in 'The Garage' started by S. Burnham, Dec 15, 2005.
  1. S. Burnham
    S. Burnham Registered Member
    Dec 12, 2004
    64
    hattiesburg, ms
    so i put my crank in and i am checking my clearance btween my rods and my cam. I have 6inch rods and they are hitting the cam lobe. they have alredy been ground at an angle by site up next to a 400 rod. my question is are you supposed to check the clearance with the timing chain on or position the cam to the nearest point. i have not put my chain on yet. i put the cam lobe to the nerest point and rotated the crank. if you are supposed to have the chain on when checking the clearances that means that a 383 is an interferance motor. If the chain breaks or you jump time then you are screwed because the cam is going to get messed up and probable a rod. i know a small bass circle cam will solve this problem but that is not an option right now. if it is just an interferance motor that is fine i just was not aware of that. does any one have an answer or did i confuse everyone, i don't type well so it is hard for me to explain things sometimes.
    thanks for any help
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Small base circle cam is the only option I know of. Not certain if setting timing and running it as an interference engine will do the job. 6" robs with a 383 is a tight squeeze.
  3. S. Burnham
    Dec 12, 2004
    64
    hattiesburg, ms
    i guess i will wait untill my machine shop opens in the mornng and find out from him. he said i could grind more off the rods i just don't know if have to because of not knowing which way to check the clearance. the kit was supposed to have come with 5.7 rods but he sent 6.0. i decided to go with them because i read several articals that it was a better setup for durability and power. I think i read to much. nothing i ever read works the same when i try it.
  4. BadBob
    BadBob 1/2 ton status
    Aug 14, 2005
    158
    Lyndon, KS
    do it with the timing chain on
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You MUST have the timing chain installed and timed properly. Removing or installing the cam on a 383 even requires that you rotate the cam as you go, to get the lobes past rods that get in the way. :eek1:
  6. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    There are only 2 cam lobes that interfere with a rod. If you use a 400 rod and a 350 piston you don't have any problems but when you use a 350 rod and a special piston or an aftermarket 6" rod and a special piston there you have to clearance the rods in those 2 cylinders to clear the cam but people clearance all the rods to keep the weights the same on all rods. Also just a reminder that a 6" rod in a 383 puts the wrist pin into the oil ring and you must use a pin to keep the oil ring from rotating.
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    very good point, if you were suppossed to get 5.7 rods did you get the pistons that go with the 6" rods and as well?
