Who has converted to fuel injection?
Discussion in 'The Injection Section' started by 78Suburban, Feb 26, 2006.
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    I know I should search, but I never find anything specific when I search... I hate to throw in the towel on my carb situation, but I may have a line on everything I need to go throttle body... What all exactly do I need to convert my 350 to fuel injection, I know I need a pump, manifold, throttle body, and a crapload of wiring stuff... do I need any special sensors? Do I have to have cats? How hard is it? If its nothing more than a glorified manfold swap and some wiring, I can do that, but I've got a feeling that it will be far harder... would love to hear some stories on swapping in fuel injection..
    thanks,
    James
  2. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    Tunedportk5
  3. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,923
    333
    Fort McMurray, Alberta
    I know a thing or two about EFI :)
    Catch me on MSN tommorow, and we'll go over the basics! Based on this, I assume you didn't get the old girl running properly?
  4. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    TTT
    anybody know of some good articles? I'm just trying to feel out how involved of a swap it would be before I dive into it. I'm seriously thinking about buying all these parts from a guy, if I think that I can have the skill to do the swap. What all sensors would I need to install? I know some of you have gone from a carb setup to Fuel Injection :wink1:
    thanks,
    James
  5. dyeager535
    26,979
    Long story short, you find a donor, and you take everything off of donor that is any way shape or form connected to the EFI, and put it on yours. :)
    Ryan B has a pretty darn good writeup in the tech section.
    Generally speaking, without hurting anything too much, and without changing the PROM, there are only three things that most GM EFI uses that you can get away with NOT swapping over: AIR, EVAP, and EGR. EGR and EVAP are pretty easy to keep in place on a "stock" setup, but AIR is usually a hassle with headers, the pump, etc.
    I'm sure I'm forgetting something or two, but that should get some discussion started. :)
  6. Russell
    Jun 23, 2000
    7,923
    333
    The only major concern I have with your engine is that camshaft.
    Might cause all sorts of issues with the TBI.
  7. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    Yeah, its probably ALOT more realistic for me to stick with a carb. I guess I need to just rebuild my edelbrock, assuming that's what my troubles are coming from. I'm gonna replace my plug wires before I crack the rebuild kit open, because I know they are causing a few problems, as they look like swiss cheeze, and shock you very badly when you touch them with the engine running, causing your buddies to laugh at you........ask me how I know :o
    thanks,
    James
  8. rotorjockey
    rotorjockey Registered Member
    Feb 28, 2004
    30
    Phoenix, AZ
    edelbrock has a complete kit to convert throttle body to TPI. It runs about $1200. I have not used it but am considering going that way myself.
  9. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    that is more than I paid for my whole truck :haha:
  10. PeteH
    PeteH 1/2 ton status
    Mar 26, 2003
    498
    San Jose
    in the process
  11. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
  12. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    convert from throttle body to mpfi not tuned ort. the are completly differnat. also he has a carb now so that kit doesnt do him any good.
