who has done a 2" body lift? prons & cons
Discussion in 'The Garage' started by yunit, May 6, 2002.
  1. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    who has done a 2\" body lift? prons & cons
    planning to do a 2" body lift, just wondering what changes you might have noticed afterwards, body roll, etc...
    thanks, pete.
  2. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Re: who has done a 2\" body lift? prons & cons
    The only down site I can think of is this - the higher body lift you install, the more leverage you are allowing the body to have on the mounts and the actual mounting locations in the very front and rear of the body. I just got done removing my 3" lift because I tore thru 2 mounts on opposite corners while in Disney.
    I repaired the damaged mounts in the body, installed a new poly mount kit, and the ORD 1" alum. spacer kit. What makes you want to go to the 2"?
    -Dan
  3. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
    I am running 38's with a 4" lift and need some more room. My truck has alot of flex and the front tires rub the firewall when the truck is flexing hard. I might just do the hockey puck 1" lift; just to get a little more out of he truck. We'll see. Pete.
    Hey that steering block I got from you worked out really well. Thanks again.
  4. captain chaos
    captain chaos 1/2 ton status
    Mar 29, 2002
    413
    dickinson, north dakota
    hockey puck's are bad!!!!!!!!
