who has done a cab swap from 2 wheel to 4x4?
Discussion in 'The Garage' started by oatsk5, Nov 14, 2003.
  1. oatsk5
    oatsk5 1/2 ton status Premium Member GMOTM Winner
    Aug 18, 2002
    1,724
    8
    Grand junction CO
    i have a 2wd truck and i got ahold of a 4wd frame and im wondering if there is any difference in cab mounting and what not . /forums/images/graemlins/thumb.gif
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    cab mounting is the same, all body stuf should swap over. Only thing that is different is the trans tunnel, the 2wd body won't have the hole for the transfer case shifter.
  3. oatsk5
    Aug 18, 2002
    1,724
    8
    Grand junction CO
    right i still have the old just in case thanx.
  4. cybrfire
    Dec 15, 2002
    15,143
    579
    Iowa
    the hump of the tunnel is higher on a 4wd if I recall. been along time since I did that swap. alot of the 4wd's had a bolt in hump. You can swap that right in and cut away the sheetmetal you don't need.
  5. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    4 speed trucks have the tall hump. Auto trucks are different. Maybe a little more than moving tunnel plates over. You could add a small body lift (1-2") to clear transfer case and/or lower case a little.
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    dont 73-up use taller body mount bushings for 4x4 and 3/4 ton and 1 ton- just like they did in 67-72?
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Nope. 73-80 frames and 81-87 have their own sets of bushings though. You need to use the bushings appropriate for your frame.
  8. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    you need to do a min 1.5 " body lift due to the lesser arch of the center hump in the cab body
    i allways do 2" as they sellthe kit like that
    or be cheep and buy the 3" kit and cut all the blocks in 1/2 and save for the next 1 or sell cheep 2 help out some 1 else
    R
  9. stump_puller
    stump_puller 1/2 ton status
    Apr 5, 2002
    871
    135
    Corbin, Kentucky
    I have done this. I could only find a 2 wheel drive cab for my truck. I had to cut a hole in the floor where the transfer case shifter goes. I went with a 3in body lift 'cause the way I measured it was about the difference between the two. Mybe it is 2in I don't know for sure. Other than that the swap is straight foward I had no problems.
    Don
    /forums/images/graemlins/truck.gif
  10. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    i just cut the whole for the transfercase shifter. everything works fine, why did you put on a body lift? i have a 400 auto trans. /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
